720 power steering flow control
pa_popper
03-27-2004 12:30:39
I took my 720 des out for a spin today and made the mistake of starting out on an incline in 6th gear. It jumped a couple times and stalled before I could pull the clutch back. After I started back up and took off, I noticed the power steering no longer worked at fast idle. It works at anything but full throttle. I imagine I yanked back on the wheel when the tractor was lurching. Did I break something, or is it a simple matter of turning the flow control screw in some? I replaced all the seals in the steering pedestal last fall. I never opened up the flow control and actuator pieces. It worked fine, though I had the steering set up with a heavier feel. Just wondering what I'm in for...Thanks.
Clooney
03-27-2004 14:39:21
 Re: 720 power steering flow control in reply to pa_popper, 03-27-2004 12:30:39
pa_popper, that's a very unusual failure mode.
I guess the place to start is to make sure the fan [& therefore the pump] is spinning at fast idle..
If that's OK, then make sure it is full of P/S fluid..
I doubt you hurt it by pulling on the steering wheel or it would also act up at idle..
The flow control could effect it but turning it in would probably make it worse as you have steering at slower engine speeds..
If any damage was done I would be more inclined to believe it was caused by the front wheels hopping off the ground & damaging the steering vane area but again you would think it would act worse at slower pump speeds..
Probably let it cool good over night then see if it still acts the same tomorrow, if so you will probably need to install a pressure gage & see what's happening there..
Post back or E-Mail with any questions..
[email protected]
