JD 40 Mower
JD40
03-27-2004 11:28:01
Does anyone run a 3 point mower behind a JD Model 40S? I have heard that you can and that you should not do this
Steve-in-GA
03-28-2004 18:33:17
 Re: JD 40 Mower in reply to JD40, 03-27-2004 11:28:01
I run a 50" rotary behind my 40S, which is an all-fuel and I have a clutch on the mower. The mower is almost too much for the tractor in heavy grass.
DMack
03-27-2004 16:00:14
I run a 50" FMC rotary brush hog behind my JD40 tricycle and have not had any problems. From what I have read in the past, it is recommended that you mount an aux. clutch between the 3pt and the mower, so that if you hit something solid, the clutch will disengage before damage is done to the pto gear. I have not done this, but my ground is very flat and relatively rock free.
Good luck,
Dave
