Added horsepower with a power block?
Mitch
03-27-2004 07:49:59
I have a powerblock in my 47 A Everyone I talk to has a different idea on the horse power. And said there are different kinds. Can anyone help. Thanks, Mitch
Duane Larson
03-27-2004 19:52:25
 Re: Added horsepower with a power block? in reply to Mitch, 03-27-2004 07:49:59
Mitch,
I can provide the following Power Block info from the 1958 Tractor Supply Catalog. The bore increased from 5 1/2 to 6", compression ratio increased to 6.5 to 1, and the block adds between 10 and 18 hp.
PBs can be supplied with special 8 to 1 high compression pistons for use with LP fuel for $5/pair. Exchange price for PB with pistons and rings was $134.50.
A later ad in the 1967 TSC states "Adds between 18 and 23 drawbar H.P.". No other properties of the block or pistons seem to be changed, but now they refer to drawbar HP. They could be referring to the LP setup, although that is not stated.
So, several different increases for HP values when PBs are used are provided in the TSC literature.
buickanddeere
03-27-2004 13:53:27
If the engine in HP limited due to airflow through the heads. Mostly the rpm at which peak torque and peak HP occurs will be shifted to a lower rpm. If airflow increases 19% with the 19% increase in displacement than power will be increased by appox 19% depending on some other thermodynamic and mechanical losses/gains. The compression will likely be increased by using the powerblock's pistons. So the engine's mechanical effiency/power output will be improved/increased. If detonation/knocking does not occur. So in short a power block in an "A" should let it keep up with or perhapes exceed a model 60 in HP. It won't catch up with a 620/630 however. Certainly won't match the fuel eficiency either.
