38 unstyled A update
Tim...OK
03-27-2004 04:29:55
I got some great advise from Clooney and John T on my water in oil situation about 2 weeks ago,unfortunately its a little worse than we hoped. Was hoping it was just water that had leaked in from sitting,but filled up radiator,and after a week of sitting,could no longer see water in radiator,drained 4 1/2 gallons of "oil" after putting in 2 gallons of fresh oil after oil change.Does any body have part number for head gasket and is correct head torque 125 ft/lbs and .020 valve lash? Didn't want to,but gonna have to do it. Also pulled valve cover,no water,does that mean that that pushrod tubes are probably ok?? Sorry to be so long winded..
thanks,
Tim in OK
gsfmech
03-28-2004 20:24:45
 Re: 38 unstyled A update in reply to Tim...OK , 03-27-2004 04:29:55
Dito on what Clooney and JohnT said about retorquing the head after it goes through a few heating/ cooling cycles. I changed out the head on my "B" last year and did not retorque it. A couple of months ago I went out to start it one morning and the engine locked up. I opened the petcocks and water ran out. I simply retorqued the head and have had no problem since.
Rudy in Tx
03-28-2004 05:26:14
Tim, you might want to check your block while you have it apart. I changed heads on mine, put in new push rod tubes and it still leaked. Finally found a crack in the no.1 piston wall on the top side-made it hard to see- and had to have the block sleeved. From what I found out this is a common place for them to crack. She runs fine now. Good luck.
Clooney
03-27-2004 15:08:47
Tim, on that water leak..
~I believe I would either remove the front wheels & lower the front or raise the rear of the tractor then remove the rocker cover, then pour a little more water in the radiator & see if any water comes out of either of the push rod tubes..
~If nothing found there, then pull the crankcase cover & raise the front of the tractor so the front is higher than the rear then see if any water comes out at either cylinder under the piston.. Or if you can see any other area where the water is entering the crankcase.
~If you don't find the leakage area before disassembly & there isn't an obvious problem found with the head gasket you will never be sure you have repaired the problem until you completely re- assemble it again.. I always try to isolate the problem area BEFORE disassembly so I know EXACTLY where to look after disassembly.. ~On the cyl head nut torque: There isn't a Deere posted spec on the unstyled "A" so just use the styled "A" torque of 125 ft lbs. Start in the center & work your way out on both sides in a crisscross pattern.. torque it up in 20# increments to start with then the last few passes go up 10# at time.. Don't forget the lead washers under the head nuts & put the machined sides of the nuts towards the head [if you can tell].. Be sure to use a little gasket sealer on the head gasket [especially around the water passage areas] & remember to re-torque the head after a few heating & cooling cycles.. You can probably use any good head gasket quality gasket sealer [personally I like #3 aviation grade Permatex] I put a [very light] coat on both sides of the head gasket but NOT on the metal fire rings surrounding the cylinder openings..
~On the valve adjustment: The spec is .020" hot but I set them to .022" cold at assembly time then run it like that until time to re-torque the head nuts.
~On the head gasket part number? It looks like it was posted below but more than likely the number has been subbed anyhow, so just ask your Deere parts man.. You can even get that gasket from your local NAPA or auto parts store but might have to buy a complete head gasket kit to get it..
Any questions just post back or E-Mail
[email protected]
JC
03-27-2004 10:13:16
Tim,
I'm more familiar with model "D"s. My I&T manual says it covers "A" tractors s/n 499,000 and up.
This manual shows the following torques:
125 lbs for model A, BUT on all heat treated studs [dark coloured studs] torque to 150 lbs for model A s.
Torque evenly from the centre out. Work the pattern several times in 10-20 Lbs steps.
Unfortunately, it doesn't state whether the threads are to be clean & dry, or clean and lubed - which makes a big difference to the resulting clamping force.
Tappets - 0.020" hot.
Regards,
JC
Tim...OK
03-27-2004 08:05:58
Thanks John for the part numbers,appreciate it. I was gonna take it to my machinist,have it checked and maybe valve job while it's off.
Tim
John T
03-27-2004 07:13:57
Hi again Tim, I guess im glad you got some advice but sorry to hearn the old girls sicker than we thought. To answer your questions:
1) MY book shows PN A 404R as the Head Gasket for an unstyled A SN 410,000 and up. It shows A 405 R as the manifold gasket.
2) I dont have the head torque specs, sorry, my friends Clooney or Duane Larson and others have some pretty good specs and other hard core techy data. HOWEVER, have the head tested for cracks, of course, and if she's good, have the block and head surfaces clean smooth and dry for installation. Ive used K & W (I believe) High Temp sealer on head gaskets, and Ive used nothing and both systems never leaked. CLEAN FLAT SMOOTH AND DRY (except for any sealant) AND SLOW SEQUENTIAL TORQUEING IS WHAT SEEMS MOST IMPORTANT.
IMPORTANT just snug the nuts down in the proper sequence/pattern, then torque in 5 to 10 lb increments a lil at a time till youre up to spec. Then after a good long warm up and achieving temperature, retorque them again. Dont forget those lead washers under the nuts and have all the old lead or residue off the studs.
NOTE 1 If the old head gasket was NOT the source of the leak, and the head shows no cracks, and the pushrod tubes were all good, make sure the block isnt cracked!!!!! !! OUCH
NOTE 2 If either the manifold or the head surface area where it mates with manifold is not flat, smooth and true (some get pitted and burned badly) I would have them planed down smooth. Be sure the manifold has no tell tale cracks or leaks or burn/rust throghs.
NOTE 3 Have the machine shop check the head for valve and guides condition and seats (repair or replace as needed) and for any excess wear in the rocker arms and shaft and I would be tempted to just go ahead and install new pushrod tubes since its off anyway if theres any doubts as to their condition. I would hate to use the old head studs if worn/corroded down badly (if you get manifold off without breaking any off, that can be tough) but replace them. DONT BORE TOO DEEP if you have to drill any out.
3) The data here shows 0.020 as the correct valve lash.
4) If the pushrod tubes leaked badly, they wouldnt run water out the front in the valve cover area unless the tractor was downhill towards the front remember. So no water where you mentioned does not say for sure they may not still be bad. Is that if they laek bad and parked front downhill and water runs out them YOU KNOW FOR SURE THEYRE BAD.
I know this may run into more work and expense than you wanted, but if you gotta remove a head anyway, you dont wanna put anythign back (like valves or guides or rockers or studs or pushrod tubes) and then it go bad later. Be sure and identify the source of the leak when all is down. A good machine shop can check the head and valve/guides and seats condition and for cracks etc and install new studs if needed and plane the manifold smooth if needed.
Keep us posted, good luck n God Bless
John T
