4520 mutiple malfunctions
Buck
03-26-2004 19:52:58
Well boys i think ive been had but im stuck with the tractor so im going to bounce a few of the problems off you guys. I bought a 4520 a while back off a auction now it seems about everytime i use it somethings going wrong. First it was the hydraulics, they would just cut out completely for a little bit then work again. It was low of oil so i filled it up and thought i had it fixed but now its becoming a problem again. Namely the 3-point not wanting to raise all of the time. Then the clutch started slipping. I got a blade on it and thought i was going to get some work out of it but i started smokeing the clutch. Now today the pto started cutting out. Had it hooked up to the rollermill and was working fine the the pto just quit. Leaving the mill full of corn i might add. Anyways i was wondering if you guys had any ideas on the hydraulics what could be happening, how much of a job putting a new clutch in it would be, and if the pto problem is related to either of these or if its something all of its own. Oh this still has the oldstyle air cleaner on it, i was wondering how important it is to upgrade it. I thought i was getting a cheaper 4020 but right now our old 4020 with 13000 hrs on it could work this dog under the table. Thanks in advance for any help. God Bless
Brokenwrench
03-27-2004 04:16:10
 Re: 4520 mutiple malfunctions in reply to Buck, 03-26-2004 19:52:58
It sounds like you have multiple problems. Your hydr. problem could be dirty filter,internal hydr. leaks that bleed off hyd. pressure,a weak charge pump,clogged suction screen,or low system pressures. This will also affect the pto because it is hydraulicly applied.Also if you have internal leaks,using the clutch alot stops the charge pump that feeds the main pump,and you loose hydraulics until the clutch is engaged and charge pressure builds up again. Try adjusting the engine clutch to give it an inch of freeplay.If it won't adjust anymore, the tractor will have to be split to replace it. Start the tractor up when its cold and let it run for 20 minutes. Go around and feel the remotess,the rockshaft housing where the feed line goes into it, the steering valve under the dash. If any of these are warm to the touch,they are leaking internally and will have to be repaired.
Buck
03-27-2004 09:26:38
 Re: Re: 4520 mutiple malfunctions in reply to Brokenwrench, 03-27-2004 04:16:10
Hey I let it run like you said, the outlets never got warm, the lines got a little warmer but im thinking it might have been more heat coming off other things. I did forget about the steering valve though so i might have to do it again. Is the adjustment on the clutch right there on the clutch pedal. If it is then ive got about 1.5 inches to work with. If there was an internal leak are we talking about something thats just letting the oil bypass back to the resevior or is it more serious than that. Thanks for the help.
