STRIPPED SPARK PLUG HOLE/ JD A
Ben.So.Tex
03-26-2004 19:10:51
Friend of mine got his 1st tractor. JD A. we have been giving it a good going over, today we put new wires and took the old plugs out, one of them was crossed treaded the new plug goes in hard, we removed it and it also is cross treaded. How can we repair this plug hole?? the plug is in the tractor now. Ben
Clooney
03-26-2004 19:24:49
 Re: STRIPPED SPARK PLUG HOLE/ JD A in reply to Ben.So.Tex, 03-26-2004 19:10:51
Ben, go down to your local [good] auto parts store & buy a spark plug thread chasing tap.. Take the old plug with you so you get the correct plug thread.. Usually that will straighten the threads out.. If that tap won't work you will have to buy an insert kit & drill it out then tap & install a plug thread insert.
[email protected]
Ben.So.Tex
03-26-2004 19:34:34
 Re: Re: STRIPPED SPARK PLUG HOLE/ JD A in reply to Clooney , 03-26-2004 19:24:49
Thanks Clooney.We will try that tommorrow,,I sure don't want to drill steel shaving will fall in the cylinder, is their any way to avoid the shaving from falling in the cylinder if we have to drill? Ben
Clooney
03-27-2004 15:15:42
 Re: Re: Re: STRIPPED SPARK PLUG HOLE/ JD A in reply to Ben.So.Tex, 03-26-2004 19:34:34
Ben, You ask?....
Quote: "is their any way to avoid the shaving from falling in the cylinder if we have to drill?"...>>> Answ, yes, well sort of.. You can just let them fall in & use Franks method to remove them.. OR, remove the petcock [or bottom cylinder drain plug], then roll the piston to the bottom of the bore, then put about 10-15 PSi of air pressure in the cylinder while drilling.. If you use his method BE SURE to wear safety glasses while drilling as those chips will blow out in your face while drilling or tapping...
[email protected]
F-I-T
03-26-2004 21:23:29
Ben:
Some of the old timers used to slather grease on the drill bit claiming all the chips would stick to the drill.
I always had the head off when I had to fix something like that, but I guess if you would release the tension off of the valves so you didn't blow a chip up the intake (up the exhaust side really wouldn't matter I guess) and then use a tube on a blow gun and really waste the air in there, you should blow anything out that could be large enough to cause a problem.
Frank
