4000 safety air filter
rctn
03-26-2004 17:13:28
Have a 4000 diesel that shows the air restriction light at full throtle. it used to show it at pto speed till I changed the main air filter. Wanted to buy the safety filter, but JD dealer wants $69.00 for it and shows it as a metal part, not a filter per say and says they have never sold one. Was told it could be cleaned. Has any one ever cleaned one? What do you clean it with? This tractor does not have a pre=cleaner. Thanks for all the help.
Rick IA.
03-27-2004 04:41:58
 Re: 4000 safety air filter in reply to rctn, 03-26-2004 17:13:28
RCTN,
I have a 71 4000. last year it ran out of power, 60 hp on th dyno. Several on the mechanics were going to pull the pump until one old boy said to change the saftey filter. Turns out it had never been replaced since new. Myself and the other mec's never knew it was there. They put a new one on and back to 110 hp. I would buy a new one if I were you, its money well spent. Rick
nwb
03-27-2004 02:34:55
I don't know what a safety filter is but I've cleaned dry element filters two ways. First I tap lightly on a cement block, Then use an air hose and blow at angles. (Never direct) Also use an OSHA blow gun and turn the air pressure down. If you can get the gun inside the filter and blow out, that is the best. Secondly you can wash with water. Repeat the above steps and then wash with a non-sudsing soap. (Murphy's Oil Soap) I use a 5 gal bucket and agitate the filter in the bucket. Then rinse with a hose. The draw back to this method is drying time. Depending on the weather or shop facilities count on 2 days to one week to dry. On my combine I got old filters from a bone yard and then just switch them.
Mike M
03-27-2004 05:07:35
 Re: Re: 4000 safety air filter in reply to nwb, 03-27-2004 02:34:55
I think they caution as to not to wash them too many times,then throw them away and buy new. I know of a guy who thought he was doing good by washing his filters, but it turns out he ruined his valve guides. The pores of the paper opened up letting in more fine dust and wore them out. Too much of a good thing can be just as bad as not enough.
david val
03-27-2004 00:08:06
i couln't find a safety element in the 4000 pc. i don't think there were any. either there is some homemade filter or your'e talking about the pre cleaner. you can run the motor with the pre cleaner removed and see if it makes a difference.
david
Mike
03-27-2004 03:22:19
 Re: Re: 4000 safety air filter in reply to david val, 03-27-2004 00:08:06
David, It is mounted on top of the air filter housing,not inside the primary filter.It takes some looking to find it in the parts book.
david val
03-28-2004 11:00:52
 Re: Re: Re: 4000 safety air filter in reply to Mike, 03-27-2004 03:22:19
well, i saw it at last in the pc. availible on tractors without pre cleaner (on which i never laid eyes). seems like a uniqe seald unit. can be searched by part number on filter manufecturers sites. if not found on the maket, price seems reasonable.
david
Pat
03-26-2004 17:33:07
I have worked for John Deere for four years and have seen no way to clean this filter. Yes it is expensive, but it lasts along time due the fact that it is a secondary filter. Don't run it to long with the light on as it is starving for air!!!!
