70D - The Crankshaft is Out !!!
Gary U in NJ
03-26-2004 15:53:52
Just wanted to let everyone know that I finally have the crankshaft removed on my 70D. It has got to be one of the hardest jobs I've ever done - mostly due to items frozen in place.
The dammage inside is isolated to the #1 connecting rod to crankshaft. The bearing spun and it appears that it hasn't chewed up the crankshaft too bad. I have yet to measure all areas, but in the mean time I have located an engine machine shop to do the work.
Now, assuming that I'll need some oversized bearings, does anyone know if stock is limited at John Deere? What about rings?
Thanks!
Gary
F-I-T
03-26-2004 21:36:17
 Re: 70D - The Crankshaft is Out !!! in reply to Gary U in NJ, 03-26-2004 15:53:52
Gary:
Glad to hear you finally got that beast apart!
I didn't have much time (just got home from LA), but here's what I found on Deere parts at a glance:
Std and .045" rings are available for either the early or later replacement piston (in the neighborhood of $175 !)
Rod bearings are available in Std, .002, .020, and .030" (around $60).
You might want to give Albert at Renaissance Tractor a call. I got my pistons and rod bearings from him. His price might be less.
Time to sleep!
Frank
Gary U in NJ
03-27-2004 02:35:18
 Re: Re: 70D - The Crankshaft is Out !!! in reply to F-I-T, 03-26-2004 21:36:17
Frank:
Many thanks for the research. Everytime I try to access JDParts.com I'm hung up - thank you so much!
You never told me about the west coast. How long are you out there and where are you?
Gary
F-I-T
03-27-2004 07:08:15
 Re: Re: Re: 70D - The Crankshaft is Out !!! in reply to Gary U in NJ, 03-27-2004 02:35:18
Oh, I working at JPL in Pasadena. Been there since Christmas. Could be there as long as October.
You gonna get out that way anytime?
