Can you HELP me again, JD440 crawler
scott
03-26-2004 12:03:04
JD 1960 440icd crawler loader/backoe combo.
I ordered manuals but I haven't got them yet.
I will be trying to start this this weekend.
Many of the hydraulic hoses are broke.
How do I shut the backhoe hydraulics off so they don't spray all over???
Can I shut all of the hydraulics off??
Must be lever of something????
I hope.
Also
I looked at the backhoe attachment underneath, there are no swing cylinders, The hoe is mounted on the tractor.
Where is swings or pivots, it round,It has two hydraulic lines into it.
Are these the turning lines? what kind of swing system is this?, all the others I have seen have cylinders that you can see.
There are john deer stickers on the hoe.
Does anybody have an idea of how this thing works for swinging left to right? And what make do you think it is???
Thanks
Scott
Thanks Scott
Brokenwrench
03-27-2004 03:42:22
 Re: Can you HELP me again, JD440 crawler in reply to scott, 03-26-2004 12:03:04
The backhoe is probably a 50 series Deere. It uses a "swing motor",instead of cylinders. This is what you are seeing with the hoses going into it. If the majority of the leaks are on the hoe,you can take it off to work on it. there should be 2 large bolts on the top of the saddle that you remove,then use the hoe to lift up off the saddle and pull foward about a foot. Shut off the tractor,crib the hoe up,so it doesn't fall while you work on it. The 2 big line that run to the hoe from the tractor can be un hooked at the quick connects and plugged together on the tractor so oil will circulate. As far as disabling the whole hyd. system,you will have to unbolt the pump coupler. If you unbolt the coupler,it would be a good time to replace the fan belt while the coupler is off,rather than have to go through all the work again later. The swing motor on those hoes is a weak area,they are prone to swing slowly,creep,cause alot of side to side slop,or leak. For a hobby machine the vanes can be replaced and motor resealed,but don't expect it to act like a swing cylinder hoe.
Mike
03-26-2004 17:47:31
The only way to disable the hyd.is to disconnect or remove the pump on the front of engine,check also it may have a chain coulper on the drive to the pump but it would probably be under the radaitor
