coolant question 2 cyl
Bill R.
03-26-2004 08:15:11
I apologize in advance because I'm sure this has been asked before, but I couldn't remember it recently. I recently replaced the head on my model R diesel and the radiator core, while the head was off we flushed the block out good also so the cooling system is in good shape. I am currently going into my '51 A deeper (block; head; rad core; gov). I was wondering what anyone recommends for an additive, I will probably try to drain and flush and refill the systems every couple years, (dirty cooling systems are my pet peeve) but I still think a good additive won't hurt, so far the only two I really know about are a coolant additive from Caterpillar that we use in the dozers, and the one from Motorcraft that I use in my powerstroke. Any suggestions/recommendations are appreciated.
(I must have a sickness because tearing the radiator and cooling system down and cleaning it out seems to be my favorite part)
Bill R.
A // B // GW // R Diesel
Henry J
03-26-2004 15:19:28
 Re: coolant question 2 cyl in reply to Bill R., 03-26-2004 08:15:11
Bill
I wouldn't even think of adding that stuff to radiators where the motor don't see much use and it is not a diesel. I do use distilled water with the mix in my vehicles.
However I do change and use the additive in the PowerStroke but that is a different animal which due to cavitation or whatever eats through the cyl walls.
There are also test strips to use to see if you need the additive, but in your case and the usage and changing you do, I would let the sleeping dog lie also. Someone will always jump at the chance to sell you some snake oil lol.
Have fun!
ChuckW
03-26-2004 09:15:57
from experience if you do much flushing around on those old radiators, you will be replacing. If they're not leaking I would suggest a 50/50 mixture and let it go. I would definetly not pressure back flush on use any pressure on any of those..leave sleeping dogs alone is my advise.
Bill R
03-26-2004 19:24:03
 Re: Re: coolant question 2 cyl in reply to ChuckW, 03-26-2004 09:15:57
Chuck, I am talking about tractors that I have been through the systems on, and those have new radiators and hoses on them, also I wasn't planning on pressure flush either. I know what you mean about old radiators however.
Bill R
