Flote-ride seat question..
mike-nm
03-25-2004 18:33:59
When I got my 730, the left-hand rubber torsion spring was broke on the seat. The right-hand one was still good but weathered. So, I went ahead and ordered 2 replacements for both and installed them about 6 months ago. The left-hand one is already starting to break while the right-hand still looks new. What gives? Did I not put them on right? I was wondering if your supposed to put some kind of preload on them before you adjust them.
Thanks to all who reply.
MIKE HANLEY
03-26-2004 04:32:22
 Re: Flote-ride seat question.. in reply to mike-nm, 03-25-2004 18:33:59
Where did you get them? There were some made over seas that have failed so bad that the one place selling them pulled them off the market. The only USA made ones that I know of and they are dang GOOD are made by MINN-KOTA REPAIR INC 38893 CO HWY 12 Ortonville Minn 56278 PH 320-839-3940 WEB SITE www.minnkotarepair.com Yes they are mounted under load and it tells how in the JD shop manuel for the 730.
We redid the 630 and one of the 730D's last fall.
mike-nm
03-26-2004 15:35:54
 Re: Re: Flote-ride seat question.. in reply to MIKE HANLEY, 03-26-2004 04:32:22
Thanks mike H.- I bought my rubber springs from a place called 'the company' , I will have to order another one for the left side and try it again. I found my receipt and they cost $55 each. Thanks again-mike-nm
MIKE HANLEY
03-26-2004 06:43:08
Somebody jump in here,,,can't find my book with the production nunbers and built dates. Aug 1958 to Feb 1960 but the book shows exact dates if I can find it.
Loren-Minnesota
03-26-2004 07:05:26
 Re: Re: Re: Flote-ride seat question.. in reply to MIKE HANLEY, 03-26-2004 06:43:08
Mike Hanley
I have seen a 60 and 70 for sale on the photo ads recently with a float-ride seat. Are these easily adaptable? If so, I'd like to put one on my 60.
Thanks
Loren
MIKE HANLEY
03-26-2004 12:48:39
 Re: Re: Re: Re: Flote-ride seat question.. in reply to Loren-Minnesota, 03-26-2004 07:05:26
Yes, as the 4 holes in the battery box that the rewg seat bolte to are the same 4 holes that the float ride seat bolt to. It just a matter of finding a float ride seat (and maybe putting new bushings and rubbers on it) and then just mount the seat on the battery box. If you use that tractor a lot, I can't say enought for the coutions that have the springs in them. They have the seats all beat that are just foam!!!!! !!!!! !!!!! They are $89 for the bottom and we also got the steel backed back rest ($48) and the side arm rests ($59) from THE SEATMAN 14215 468th Ave Wilmont SD 57279 PH 605-432-6192.
Loren-Minnesota
03-26-2004 15:15:12
 Re: Re: Re: Re: Re: Flote-ride seat question.. in reply to MIKE HANLEY, 03-26-2004 12:48:39
Thanks Mike,
I have a herniated disc in my lower back and anything would help. Just plowing snow this winter beat me up pretty bad.
Loren
mike-nm
03-26-2004 15:41:42
 Re: Re: Re: Re: Re: Re: Flote-ride seat question.. in reply to Loren-Minnesota, 03-26-2004 15:15:12
Loren- you will like those seats, they might be a bit too comfy- I almost could fall asleep plowing.-mike-nm
OPPS
03-26-2004 06:49:20
must still be sleeping this is the answer to the 430 question
