Changing fuel valves on 630lp
Rev JJ
03-25-2004 18:07:53
Is there any trick to doing this without pulling the steering wheel and WHOLE dash off? who makes the best steering wheel replacement (the old one is shot).
Found out both valves were leaking AFTER mounting four row planters!
Tommy
03-25-2004 20:26:28
 Re: Changing fuel valves on 630lp in reply to Rev JJ, 03-25-2004 18:07:53
Rev JJ, I don't think you can do it with the steering wheel support in place. I looked at mine when the vapor valve was leaking and it didn't look like there was any room to work in there. I was restoring it anyway so I was going to tear it apart to paint so it was no problem for me. Are your valves leaking when open and closed. If they leak when only closed you CAN leave them open all time if you need to have the tractor for planting. There is a fellow here who has never turned the liquid off on his 70 and it don't seem to hurt anything. I KNOW that is not correct but he does it. You may be able to get away with that for a short period of time to do the planting then fix it. You may want to replace the hoses while you are in there. If you leave the valves open, don't put it inside until it is repaired.
TT
