70 PTO can't turn by hand Clooney, FIT
Gordon
03-25-2004 17:42:25
Clooney, did as you said everingthing disengaged,can only turn with pipe wrench also when running under load cluch housing got very hot, tractor is a late 70. FIT, looked at both bearings looked ok, but bearing cover was under spring tension until I engaged seat lever, is that the way it should be. Thanks for your help
Clooney
03-25-2004 18:00:45
 Re: 70 PTO can't turn by hand Clooney, FIT in reply to Gordon, 03-25-2004 17:42:25
Gordon, the rear clutch must be engaged not disengaged to turn by hand. With the rear clutch disengaged the brake will come on so you can't turn it.. Even with the rear engaged & the front disengaged it will turn hard due to the gear reduction & multiple gear sets..
~Usually when the rear housing gets hot there is friction somewhere.. Usually a dragging PTO brake or a slipping clutch pack.. Maybe the PTO clutch isn't adjusted correctly & the brake isn't clearing enough.. If that brake isn't clearing enough it will be real hard to turn even with the rear engaged & the front disengaged..
[email protected]
Gordon
03-25-2004 18:08:03
 Re: Re: 70 PTO can't turn by hand Clooney, FIT in reply to Clooney , 03-25-2004 18:00:45
Clooney, how do I adjust it since I don't have an adjusting screw? Thanks for your help
Gordon
03-25-2004 18:07:50
Clooney
03-25-2004 19:01:06
 Re: Re: Re: 70 PTO can't turn by hand Clooney, FIT in reply to Gordon , 03-25-2004 18:07:50
third party image
Gordon, basically you have to remove the 2 pipe plugs on the R/H side of the PTO housing, one just under & in front of the fork shaft & one just to the rear of the clutch fork shaft.. You will also have to drain the PTO oil level down..
~Then look in through the rear hole as you snap the PTO clutch in & out.. The PTO brake has to move to the rear about .090" .. Find a .090" wire & bend it to go between the brake disk & brake collar.. If the brake isn't moving about .090" look in the front hole & turn the PTO shaft until the set screw [later units] or [metal tang in the slot] early units appears.. Then bend that tang out of the slot & turn the adjusting cam [use a screw driver or punch to turn it], or turn that set screw all the way in until it clears the cam [late unit] then adjust the cam same as above.. When you get that brake to move about .090" when you snap the PTO clutch in, bend the tang into a cam slot, or back the set screw back out to lock the cam from turning..
~There is a fork stop that also needs adjusting so look at the picture & let me know if your tractor has the shown fork stop screw [that isn't the clutch adjuster screw]..
~It's getting bed time for me so you will either have to wait till tomorrow for more follow up or maybe Frank can take over from here tonight..
[email protected]
