430 tricycle
T clay
03-25-2004 17:31:57
can anyone lead me to a spec. sheet for this tractor. years,length,weight ect. thanks
MIKE HANLEY
03-26-2004 04:23:39
 Re: 430 tricycle in reply to T clay, 03-25-2004 17:31:57
Specs are;
WHEEL BASE 82 1/2"
CROP CLEARANCE 21" UNDER REAR AXEL
OVER-ALL LENGHT 130 5/8"
OVER-ALL HEIGHT 76 5/8" to top of muffler
OVER-ALL HEIGHT 58 5/8" to top of grill
TIRES AVAILIBLE; 6.00x16 FRONTS, 10-34 or 12-28 rears.
4 Speed transmission regular 1st gear 1 5/8 MPH 2nd gear 3 1/8 MPH 3th gear 4 1/4 MPH 4th gear 12 MPH REV 2 1/2 MPH 5 Speed transmission opitional 1st gear 1 5/8 MPH 2nd gear 3 1/8 MPH 3th gear 4 1/4 MPH 4th gear 6 1/4 MPH 5th gear 12 MPH REV 2 1/2 MPH
540 standard PTO 540 coninous running PTO opitional
shipping wt appox 3000#
CAPACITYS 2 cylinder upright engine with 113 cu in rated at 1850 RPM's Engine oil 5 qts Cooling sysrem 10 1/2 gals
NEB OFFICAL TESTS (420 tested, same as 430) Calcuated horsepower 27.08 on the drawbar 29.21 on the belt. Weigth of tractor as pulled 5781# with 405# of fluid in each rear tire and 690# of cast wts per wheel. 2.326 gals of fuel used per hr under max load 1st gear 1.58 MPH pulled 3790# 14.50 wheel slip 2nd gear 3.32 MPH pulled 2782# 8.22 wheel slip 3th gear 4.45 MPH pulled 2073# 5.97 wheel slip 4th gear 11.63 MPH pulled 710# 2.48 wheel slip
MIKE HANLEY
03-26-2004 06:51:23
 Re: Re: 430 tricycle in reply to MIKE HANLEY, 03-26-2004 04:23:39
Some body jump in here,,,,can't find my book with the production dates and numbers. aug 1958 to Feb 1960 but the book shows the exact dates.
Phil Hunsberger
10-11-2006 20:12:51
 Re: Re: Re: 430 tricycle in reply to MIKE HANLEY, 03-26-2004 06:51:23
Regarding above where production dates are emntioned for the 430 model JD tractor; I always hear that Dubuque didn't keep records for building and shipping (that anyone ever found later) for their little 30 series fellows! Does someone know of the source/books?
