70 PTO Can't turn by hand
Gordon
03-25-2004 16:33:43
Have grinding sound from PTO area when under load.With pto disengaged I cannot turn pto shaft by hand. Should I be able to? If not, could it be in clutch pack, or bearings somewhere? Also, I do not have adjusting screw in clutch housing as pictured in manual. Since my tractor is XXXX301 is the second late model 70 built. Did early models not have adjusting screw hole in clutch housing and could my late 70 have one of those housings on it. Thanks ahead of time for ny help that you can give me.
F-I-T
03-25-2004 17:19:30
 Re: 70 PTO Can't turn by hand in reply to Gordon, 03-25-2004 16:33:43
Gordon:
Let's breakdown you questions.
>>Have grinding sound from PTO area when under load. With pto disengaged I cannot turn pto shaft by hand. Should I be able to?
I think thet a properly adjusted P-shaft will rest against the internal brake pad, so if the brake is properly adjusted, it would not turn by hand.
There are four bearings, and they can fail.
Do you mean the adjusting screw that would exit the top of the P-shaft clutch housing, toward the Powr-Trol housing? That was discontinued at 7031299, so your should not have that adjusting screw.
I'm not sure here what you mean. There are two plugs, the one nearest the tractor gives you access to the PTO clutch. This is where you adjust the gap.
Does your clutch work all right, but it just growls? The two outer bearings can at least be viewed from the outside if you remove some covers. You might be able to get an idea of the cause.
Frank-in-Tallahassee
�56 70D // �90 855 // �50 VAC // �48 Cub
[email protected]
F-I-T's webpage.....ALWAYS under construction....
Clooney
03-25-2004 17:16:55
Gordon, there is an internal brake that stops the PTO with it disengaged.. If you want to turn it by hand, just snap the PTO seat box lever into the engaged position then take the front PTO lever [up by the shifter] out of gear. That releases the rear brake & unhooks the front drive.
~On that adjusting screw? I presume you are referring to the set screw in the adjusting cam inside the PTO clutch. If so, the early 70 tractors [prior to S/N 7010775] used a metal plate with a tang bent into the cam slot. Just pry that metal tang out of the cam slot to make the adjustment, then bend it back when done..
[email protected]
