FIT on Rims
Henry J
03-25-2004 13:44:15
Frank
Man, I like those rims. Is there a chance you still have the paint can sitting around that you could shoot me a paint number from?
Thanx
F-I-T
03-25-2004 14:14:36
 Re: FIT on Rims in reply to Henry J, 03-25-2004 13:44:15
Henry:
When I get home this weekend I will gladly check out the paint number. It's a PPG DAR acrylic enamel product.
Frank
Henry J
03-25-2004 18:09:04
 Re: Re: FIT on Rims in reply to F-I-T, 03-25-2004 14:14:36
Thanks Frank, I will be looking for it.
JDGnut
03-25-2004 14:22:12
FIT... Are you the one that has the PPG paint code (mixing instructions) posted on the web?? I have them printed off.. but I was curious to see who's tractor that the codes came from... Might be using some PPG Urathane (sp) I'll see if I can find the address of the code..
JDGnut
F-I-T
03-25-2004 15:07:42
 Re: Re: Re: FIT on Rims in reply to JDGnut, 03-25-2004 14:22:12
third party image
JDGNut:
Yes, that's me. The green is PPG and the Yellow is DuPont.
Here's a picture of the '70' wearing those codes.
Frank-in-Tallahassee
�56 70D // �90 855 // �50 VAC // �48 Cub
[email protected]
JDGnut
03-25-2004 15:20:54
 Re: Re: Re: Re: FIT on Rims in reply to F-I-T, 03-25-2004 15:07:42
Yup.. that's the code sheet I have printed out... I was just going to use John Deere paint with hardener.. but after a few $$$ in the primer.. (haven't even started on the sheetmetal yet.) I don't think I want to put the $30 paint over that primer... (but no complaints on any of my other tractors painted this way... ) Thanks
JDGnut
F-I-T
03-25-2004 15:45:22
 Re: Re: Re: Re: Re: FIT on Rims in reply to JDGnut, 03-25-2004 15:20:54
That is exactly where I ended up. I was spending more on primer than paint! A few more bucks and I had a more durable finish.
I have been very pleased with this paint for color and shine.
Frank
JDGNut
03-26-2004 17:33:10
 Re: Re: Re: Re: Re: Re: FIT on Rims in reply to F-I-T, 03-25-2004 15:45:22
Stopped by to price the Green paint in PPG.. using the codes U gave me.. it was going to be a little over $300 for paint and harder.. for a Gallon... That was for a single stage... A little steep.. Might look at the Imron... or Just paint the sheet metal.. (not sure it will match..) I"ll have to sleep on the idea... They couldn't change it to an Omni paint (also a PPG product) Thanks
JDGnut
F-I-T
03-26-2004 21:14:01
 Re: Re: Re: Re: Re: Re: Re: FIT on Rims in reply to JDGNut, 03-26-2004 17:33:10
JDGNut:
The PPG DAR acrylic enamel I use runs about $32 a quart. I'm sure a gallon would be less than 4 times. My hardener is the "Wet Look" brand and runs about $20. The reducer is around $17 a gallon. Sounds like either your dealer isn't pricing DAR to you or he's got a pretty severe markup!
I have also used the DuPont Limco 123 brand (on another brand of tractor) and it is much cheaper, but you'd have to paint a panel and have them color match it. I don't have a code for that one.
Frank
JDGnut
03-26-2004 21:56:58
 Re: Re: Re: Re: Re: Re: Re: Re: FIT on Rims in reply to F-I-T, 03-26-2004 21:14:01
I was looking at using a single stage Urathane but price might send me a different direction... Thanks
JDGnut
