Axle housings?
Mike S.
03-25-2004 12:50:09
I have was curious when JD changed rear axle housings from rounded type to the squared off type? I have what i believe is a 47 B ,by the serial #) with a squared off axle housing. I believe it is wrong.
Loren-Minnesota
03-26-2004 03:11:56
 Re: Axle housings? in reply to Mike S., 03-25-2004 12:50:09
John Deere went to the square axles on the B before the A, but I don't think it was as early as 47. We have a 49 B and a 49 A. The B has the square axle and the A has the round. I'm not sure when it was changed, but the B was earlier than the A. I have a discussion saved here somewhere (can't find it now) about the changes for the 1950 A (which we also have). CLW, I think you may have been in on that discussion. Apparently there where 3 changes during the 1950 production year. Very early ones still had the round axle. Mid year had a different choke and throttle linkage. Late year went to the newer style cast wheel, with the 4 extra round holes, and the choke moved again. I will look and see if I can't find that, either on my computer or in the archives. Loren
CLW
03-25-2004 14:07:57
Mike, the change to square axles was made in the late 49 model. The decals were moved farward on the hood at about the same time. Your B may be newer than you think.
CLW
