Complete operator's manual for John Deere Model A
Lee Findley
03-24-2004 20:00:03
I've got a copy of the original John Deere Model A operators manual. It's amazingly good for its time, but there are not clear pictures and schematics to identify all the lube drains, fills, and check ports. Does anyone know of a more complete manual or just a lube schematic for the A? A is a 1951, 676,000 range serial number.
Duane Larson
03-25-2004 06:41:13
 Re: Complete operator's manual for John Deere Mode in reply to Lee Findley, 03-24-2004 20:00:03
Aguy,
I have an Operator's Manual OM-R2002R for the JD Model "A" series Tractor (Serial No. 648000 and up) (Info taken from the front cover), and p. 24 has a diagram showing all grease fittings and greasing frequency, and p. 25-30 shows crankcase, transmission, and power lift drain and fill locations.
I don't know of any other source of information - repair manuals do not normally address maintenance issues.
I'm not sure what JD provides today for an Operator's Manual - but literature dealers normally have original's, or they are available on eBay.
Lee Findley
03-25-2004 07:10:27
 Re: Re: Complete operator's manual for John Deere in reply to Duane Larson, 03-25-2004 06:41:13
Thanks, Duane. The manual you describe is the one I have too, although without the R on the end of the manual number. Page number references are the same as you said. What I'm missing is identification of a drain or check plug about 5 inches above and to the right of the oil check plug. I think it may be to check transmission fluid but can't confirm that. Do you happen to know what it is? It's about an inch in diameter with a square end. Thanks again.
Lee
Jack
03-25-2004 08:10:36
 Re: Re: Re: Complete operator's manual for John De in reply to Lee Findley, 03-25-2004 07:10:27
It's the port through which you can adjust you "A"'s oil pressure relief valve. When you remove the plug, you will see an adjustment screw with a springmetal tang to hold it at a particular setting. It won't do much for worn out bearings, however, it is useful after an overhaul if pressures seem too high.
Dave in Dallas
03-25-2004 08:07:28
Lee if the plug you are refering to is above and to the front of the engine crankcase oil level check plug, it is for access to the engine oil pressure adjusting screw. Dave
Lee Findley
03-25-2004 09:03:51
 Re: Re: Re: Re: Complete operator's manual for Joh in reply to Dave in Dallas, 03-25-2004 08:07:28
Many thanks to Duane, Jack and Dave for responses. Now I know not to expect fluid of some kind to need to be added until it flows out that port! I'm using the A for mowing our pastures, enjoying almost everything about it (having grown up with one in Missouri--I'm in Oregon now), and learning as I go!
Lee
