Is a 1961 John Deere 1010R a Positive+ or a Negati
Rick
03-24-2004 18:15:37
I have a 1961 John Deere 1010 that will not charge the battery. Ever since I got the tractor the ground has been on the negative post on the battery. While the tractor is running you pull the positvie cable off the + post and she still runs and all the gauges still work, so I think the generator is working fine? A friend of mine said he thought that all 1010's were a positive gournd. I called the dealer and they said they weren't sure? Do you guys know? Positive ground OR negative ground?
Thanks guys.
Rick
03-25-2004 16:24:21
 Re: Is a 1961 John Deere 1010R a Positive+ or a Ne in reply to Rick, 03-24-2004 18:15:37
Thanks for all the help guys. I will try all the advice you all have given me and see how it goes this weekend. Thanks
Clooney
03-25-2004 02:26:49
Rick, your 1010 came from the factory as a positive ground.. As Bob said, it will work equally well at either ground as long as the generator is polarized to match the installed battery polarity..
~With that tractor staying running with the battery disconnected it is charging somewhat [at least with enough current to power the ign coil]..
~I guess the place I would start is to put a voltmeter across the battery posts with it running at fast idle... If the battery voltage is much above 13.5 it is at least charging. You would like to see a higher charging voltage like 13.7-14 volts.. If the voltage is correct you then have a bad battery, battery drain, or intermittent slipping generator belt.. Grab the generator fan & try to spin it by hand [obviously tractor not running], if it spins easily your generator belt is slipping [so tighten or replace that].... Also pull one of the battery cables off the battery & place your volt meter across the removed cable & the battery post it was removed from, if you show much over 3-5 volts draw you have a battery drain like an accessory staying on or a wire partially shorted to ground.. If you do in fact have a draw that is probably what's draining your battery when the tractor sits for a while.. If no draw [battery drain] found remove your battery & have it load tested..
~You could change that tractor back to positive ground but if it has operated ok at negative ground in the past I see no reason to do that now..
~One other thing you might be fighting: That tractor came with a positive ground voltage regulator.. In some cases those voltage regulators might not last very long when run a polarity they weren't designed to operate at.. It's possible your voltage regulator has finally started to act up so won't properly operate the generator field all the time [the voltmeter across the battery posts should show that so do that test a few different times]..
~If your generator isn't charging correctly try grounding the [F] post to the generator's case, if it then shows a good charge you probably have a failed [or failing] voltage regulator or a poor regulator ground..
~Post back if you find your charging voltage low or if you find a draw to ground in the above tests.. It might be as simple as a bad battery...
[email protected]
John T
03-24-2004 21:38:58
Rick, I dont work on ones much that have more than 2 cylinders, but thought the new generation were still at POSITIVE ground until they started using alternators. It should still charge regardless, so long as all else is correct, the Voltage Regulator is compatible, and she got polarized. However, if it got changed and it has an ammeter but the leads didnt get swapped, it could read bass ackwards.
You have an ammeter??? If you turn the lights or ignition on tractor not running, does the ammeter swing to - discharge????? ??? How do you know shes not charging????? A bad battery can run down when setting or a short or bad VR can discharge it. Has it been load tested??? Is there electrolyte above all the plates and no milky or gray colors in any cells??? (bad cell)
1) I think I would start with polarizing in case she was polarity reversed but never polarized properly. To do that, take a wire and momentarily flash jump the Voltage Regulators BAT and ARM (or GEN) terminals together and you should get a spark. DO NOT APPLY HOT VOLTAGE TO THE FIELD POST ON THE GENERATOR
2) Next make sure the belt is good and tight and not glazed and then make sure that the Gen has a good ground connection to the tractor and the VR has a good ground connection to the Generator. If in doubt, you could run a wire from the batterys grounded post down to the Gen and VR to make sure of a good ground.
3) Next make sure that the BAT terminal on the VR shows hot battery voltage at all times. The gens output cant get to and charge the battery if its not connected to the battery. If its not hot, a wire may be broke or missing or shes not wired correct. THAT HAS TO PASS BEFORE MOVING ON
4) Start the tractor and see if she charges??
5) As shes running if she dont charge, take the FLD wire off the VR and attach it to the Generators frame and see if she charges then. If so but not before, the gen is okay but the VR may be bad and its not providign a good field ground path.
6) If she still wont charge, keep her running and keep the Field grounded and then use a jumper wire and momentarily jump the VR's BAT and ARM terminals together. If that makes her charge, the gen is okay but the VR's cutout relay or wiring may be bad.
7) If you have no ammeter or idiot light, if shes charging, the batterys voltage should rise from 12.6 to 13 or 14 or so and/or the lights glow noticeably brighter as RPM increases.
8) Another way to check the Generator is the motor test. To do that remove the belt and if you apply hot battery voltage to the Generators ARM post, she should run/motor. If so, the Brushes and Amature are probably good. Then while running if you ground the gens FIELD post to its frame, she should slow down some. If so, the Field is likely okay.
Common causes of non charging are worn brushes or the brush hold down spring assemblys are broken or stuck corroded and not holding the brushes tight down against the commutator. Other causes abve are shes not wired right or a wire is missing and/or the VR's BAT terminal is not hot and connected to the battery.
I hope this answers your questions and provides some troubleshootign tips. Post back or e mail me at [email protected] any questions and your findings and I will try my best to help you.
Good Luck n God Bless
John T Nordhoff
Bob
03-24-2004 19:38:28
Your generator will work equally well with the battery hooked positive or negative ground, if it is polarized before starting the engine after any battery polarity change. If it is a gas engine, and it remains running with a battery cable pulled off, the generator must be working to some extent. It sounds like the voltage regulator is set too low for adequate battery charging.
If this is a gas tractor, the primary connections on the coil should match the battery ground polarity for a hotter spark and longer point life.
Negative ground system... Power from ignition switch to (+) side of coil, distributor to (-) side of coil.
Positive ground system... Power from ignition switch to (-) side of coil, distributor to (+) side of coil.
Handsome Jim
03-24-2004 18:27:44
Our 1010 is positive ground but thats not to say that all of them are.HJ
