50 overhaul piston caps
Randy g.
03-24-2004 17:18:44
I am re- installing the pistons and noticed piston 1 has piston 2's rod cap on it and vise versa. The pistons came out of their correct cylinders and the stamps on the rods and caps were facing up. Should I put the rod caps back on the correct piston rods or should I put them back the way they came out? The block was checked out OK, crank was not removed.
Clooney
03-24-2004 17:44:06
 Re: 50 overhaul piston caps in reply to Randy g., 03-24-2004 17:18:44
Randy, that's a tough call.. You really don't know the history of the swap or if those caps are even from those rods.. I guess if it were me I would assemble the rod caps without the bearing inserts both the original way & the way they were when you took it apart then use an inside mike or snap gage & see which way they are closet to the same size & closer to being round.. I never get a good warm fuzzy feeling when I run into something like that..
[email protected]
doug vose
03-24-2004 17:36:26
first, are you shure that you didnt accidentally swap caps around. If in fact the caps were like that when you pulled the engine apart, put them in like they came out, because the bearings have wore to the crank like that. if you put them in any other way, there is a chance of crankshaft damage, which is expensive.
