2355 no oil getting into brake valve
Scott
03-24-2004 14:52:03
I had my 2355 split to do some repairs to transmission now I have it back together it doesn't seem to be pumping oil into brake valve,any ideas why this would be.
david val
03-24-2004 22:52:27
 Re: 2355 no oil getting into brake valve in reply to Scott, 03-24-2004 14:52:03
oil flow into the brake valve was in earlier models through a small orifice in the brake valve body that was supplied by the oil flowing from the rear pump to the front pump. if the orifice is plugged or a wrong (newer)gasket was installed, or there is no pressure in the front pump supply circuit, the valve wouldn't fill up.
on newer models, the oil supply came from the banjo fitting on top of the reservouir located ahead of the radiator. there is a restrictor in the banjo fitting that alowes a small aount of oil to flow through outside plumbing to the top of the brake valve. this system elevates oil level of brake valve to prevent air entering the brake circuit through small leaks in the brake pistons. if this system is used, the brake valve gasked is designed to plug the orifice in the brake valve. in order for the brake valve to fill the reservouir must be full and pressurized and all the plumbing shuld be right.
if the reservuoir dosen't fill up in a few seconds in either systems, something is wrong with the main pump supply and maybe caused by the work done on the tractor.
in either cases, filling of the brake valve is done through restrictors and it takes a few minutes for the valve to fill up.
david
