Friends JDA leaking fuel out the petcocks
Ben.So.Tex
03-24-2004 13:39:46
Friend just bought a model(1951) A when you turn the gas on and leave it on fuel is getting into the cylinders,I check the float and it had a hole in it, I took one out of my spare carb installed it and it still leaks, could it be a bad neddle seat, or do I need to ajust the float to correct the problem? thanks Ben. ( this is his first tractor )
Clooney
03-24-2004 16:00:03
 Re: Friends JDA leaking fuel out the petcocks in reply to Ben.So.Tex, 03-24-2004 13:39:46
Ben, start by dropping the float bowl down & turning it over then looking at the float setting.. The top of the float should be about parallel with the gasket surface on the float bowl & up from the gasket surface about 3/8" all the way around..
~You might want to pull that float bowl right off the tractor [or just drop it down],, Then put a cork in the bottom hole, then hook a fuel line [or line from a liquid source] to the carb's inlet fitting, then watch the bowl... If you have a needle leak, or float sinking, or other problem the float bowl will overflow.. If the fuel level stays below the top of float bowl you a different problem like maybe a plugged bowl vent in the top of the float bowl allowing the fuel to siphon from the main nozzle..
~Give it a look & see what you find..
Any questions just post back or E-Mail..
[email protected]
John T
03-24-2004 15:33:40
Dear Ben, the short answer to your question is YES, it could possibly be that if the new float is actually good and adjusted and rises, yet the carbs bowl still overflows gas which gets into the crankcase, the needle and seat (or other causes) could be failing to shut the gas off. I will just address the needle and seat issue now since thats your main question and can address other causes if they should later arise. No use in trying to cover each and every situation now and risk confusion until we know a bit more.
If youre sure the float is rising but the needle and seat are not closing gas off, you might try and clean it out first before getting a new one, cuz its easy and typical for dirt to stop the seal and/or gum and varnish prevent the needle from rising and closing properly.
Its possible to clean some gum and dirt n crud and varnish in the needle/seat area by removing the carbs strainers top nut and cap (may need a new gasket) and cleaning it out with carb cleaner etc. If she still has crud or varnish or dirt thats preventing a good seal, you might try to remove the bowl and remove and clean and check the needle and seat. Remember when you reinstall, that lil fine springy thingy sort of hooks under the floats tab and of course, as the float rises its supposed to raise the needle into the seat and shut the gas off.
NOW, Ive had BOTH the neoprene and plain needles and like the regular but some people have better luck with the tipped needles. Ive heard some people who after installing a regular needle tap it very very gently with a very small hammer claiming that helps its fit.
I guess youre sure the new float is good and rises, is adjusted close to right, and is not a leaker????? If its a brass one and has a leak, it will emit air bubbles if you place it in hot water. If the needle and seat are leaking, shut the gas off after turning the tractor off.
As you know, if overchoked some gas can run out the petcocks, but it sounds like you mean shes running a bunch of gas out right????
Post back or e mail any questions to [email protected] and I will try n help you out more or with other possible gas overflowign the carb problems.
best wishes n God Bless
John T
John T (more info)
03-24-2004 15:56:07
 Re: Re: Friends JDA leaking fuel out the petcocks in reply to John T, 03-24-2004 15:33:40
Sorry Ben, I keep tryign to answer questions in a hurry cuz I have clients calling and have to go to Lions club and its hectic hereeeee lol. I see you also asked if its pssible the float needs adjusting, and the answer is again YES. However, it has to be fairly bad out of adjustmet if its set to where it rises but never enough to raise the needle sufficient to shut the gas off. I rough them in to where when they raise to about level that shuts the gas off and look and see if slight lil finger pressure stops the gas flow.
John T
Chris
03-24-2004 15:01:53
Does it still have the old metal tipped needle in it? They will leak sometimes. You should probably set the float while your in the carb just to be on the safe side. Don't have specs but think you can find them on this site. If the needle is the old metal tipped one throw it away and buy a new needle (with the black end on it) and seat. Think the needle tip is supposed to be neoprene. It should solve your problem. Be carefull when setting the float because if you put a ring on the needle you will be back where you started. My B gets gas in the cylinders but I just started turning off the gas when I shut it off. Let us know how it works out.
