6 Volt Generator
JD 40
03-24-2004 12:48:01
On the 6volt generator is the F positive and the A negative? Or di I have it backwards
tks
John T
03-24-2004 15:02:52
 Re: 6 Volt Generator in reply to JD 40, 03-24-2004 12:48:01
Dear JD 40, The tractor came from the factory wired as POSITIVE ground. However, regardless of its configuration, the Field windings get connected out the gens FIELD post to "chassis frame" (i.e. the batterys GROUNDED POST) via the Voltage Regulators Field Control Relay so the current path is completed and she develops a magnetic field and charges. The generators Armature post gets connected to the batterys UNGROUNDED POST via the cutout relay in the Voltage Regulator then the VR's BAT terminal.
Therefore, if youre at POS ground, the Field post is electrically positive and the Armature is electrically negative.
Regardless if youre POS ground as original or NEG ground, many people still refer to the frame as ground and as thats the batterys negative in most late auto applications, so the terminology could get cornfusing.
I hope this answers your question, so post back or e mail me at [email protected] with any questions or problems and I will do my best to help you out.
Good Luck n God Bless
John T
Clooney
03-24-2004 13:02:50
JD 40,, actually the generator case is positive [as well as the tractor frame].. The [F] post is for the field control [it's neither positive or negative but gets grounded by the regulator to control generator output.. The [A] post is the generator's power output post & that goes to the cut-out points in the regulator, then on to the ammeter, then on to the battery's non grounded post..
~If, the reason you are asking is for your hour meter hook up? Your hour meter hooks to one terminal of that oil pressure switch, then the other oil pressure switch terminal hooks to the NON distributor side of the ignition coil.. When Mark said "If your tractor still has a generator it goes to [hooks to] the negative side" he was saying [if your tractor STILL has a factory generator it hooks to the negative side on the ignition coil]..
~If your tractor in now positive ground post back or E-Mail as the leads to the hour meter will have to be reversed for it to work correctly..
[email protected]
