JD 40 Oil Pressure switch
JD40
03-24-2004 10:41:59
There are two wires that come off the oil pressure switch, one sgoes to the Hour Meter, but where does the other one go?
Mark
03-24-2004 15:59:46
 Re: JD 40 Oil Pressure switch in reply to JD40, 03-24-2004 10:41:59
If the wire from the oil pressure switch is hooked to the negative side of the coil, and the other wire from the sender to the hour meter, it would be a positive ground system and shouldn't have to switch the wires to make the hour meter work correctly. The wire to the negative side of the coil would be the power wire from the ignition switch, then down to the oil pressure switch. When that switch opens,after the engine starts it provides a current back to the hour meter so that it only counts hours while the tractor is running.
Mark
03-24-2004 10:55:05
It goes to the coil. If your tractor still has a gen. it goes to the negative side.
JD40
03-24-2004 11:36:15
 Re: Re: JD 40 Oil Pressure switch in reply to Mark, 03-24-2004 10:55:05
Thanks Mark,
Do you happen to know on the Generator is the F positive or is the A positive
tks
Clooney
03-24-2004 13:04:15
 Re: Re: Re: JD 40 Oil Pressure switch in reply to JD40, 03-24-2004 11:36:15
JD 40,, actually the generator case is positive [as well as the tractor frame].. The [F] post is for the field control [it's neither positive or negative but gets grounded by the regulator to control generator output.. The [A] post is the generator's power output post & that goes to the cut-out points in the regulator, then on to the ammeter, then on to the battery's non grounded post..
~If, the reason you are asking is for your hour meter hook up? Your hour meter hooks to one terminal of that oil pressure switch, then the other oil pressure switch terminal hooks to the NON distributor side of the ignition coil.. When Mark said "If your tractor still has a generator it goes to [hooks to] the negative side" he was saying [if your tractor STILL has a factory generator it hooks to the negative side on the coil]..
~If your tractor in now positive ground post back or E-Mail as the leads to the hour meter will have to be reversed for it to work correctly..
[email protected]
