1953 John Deere 60 Possible cam problem?
Chris Armes
03-24-2004 10:26:24
I got a new carb from Burrey carb put it on my tractor and still having trouble with #2 cylinder not running right at idle or full throttle. Like I said in the past, had block bored .045 over new rings and NOS .045 over cast iron pistons. The head has been reworked and I have installed a new intake/exhaust manifold. I have also installed new wires, cap rotor, points, condensor and Autolite 388 plugs. The bushings in the dist are good and the advance weights seem to be working properly. After all this work and it still runs like it did before I tore it down. I forgot to mention that I checked the cam timing and every thing was on its mark. Any suggestions on what to do now would be great so I can quit pulling my hair out as I don't have much left!
Thanks in advance, Chris in Fountaintown, IN
Mike F
03-24-2004 18:29:38
 Re: 1953 John Deere 60 Possible cam problem? in reply to Chris Armes, 03-24-2004 10:26:24
I dont think plugs is your trouble, I would focus on two things, one, I would take a look into valve adjustments and make sure the cam bearings are not shot, this can make a real headache as they can be set, but will not stay at the setting you put them at when its running, two, I have a hunch it is still in the carb, there are 3 very small holes by the throttle side butterfly discs, 3 for each barrel, if any of these is even slightly plugged, it wont work right, but you did say you tried other good carbs, also, try new valve springs or shim up to stiffen it , I had this trouble on my 60 and it fixed it, you can simulate this when running with the valve cover off and push on the rocker arms and hold alot of tension on them, mine straightened out nicely, bet this is your problem, Mike
Clooney
03-24-2004 18:27:26
Chris, try to explain what you mean by "still having trouble with #2 cylinder not running right at idle or full throttle"?
~Is that full throttle problem under a pulling load or just fast idle load?
~You could possibly have a cam problem but that usually doesn't effect both idle & full throttle.. I would more suspect a cam bearing problem allowing the cam to jump around but even then they usually run good once in a while [loose cam bearings cause an erratic running problem]..
~I suppose you could also have a worn governor R/H bearing or governor case bore allowing the distributor drive to fluctuate.. [You might want to put a timing light on both the L & R plug wires & watch for a scattering spark or spark that doesn't fire in the same place 2 times in a row]
~Another thing you might try is pulling the distributor & rotating it 180� then swapping the wires from tower to tower.. Then see if your problem moves to the other side. [If the problem side changes you know where to look]..
~It doesn't sound an awful lot like a carb problem or vacuum leak .. A carb problem usually only acts up at idle or full throttle but not both.. A vacuum leak usually only effects idle, at a wider throttle plate openings a small vacuum leak wouldn't even be a small percentage of the total air entering the engine so would have no effect & if the vacuum leak was severe it wouldn't idle at all or at least wouldn't idle down very low.. Try running with the choke partially back on to see if that helps, if so you have a carb or intake leak problem..
~On thing to check is the manifold heat valve.. It MUST be set to either full HOT or full COLD.. If set in between it effects the exhaust flow & can severely effect the cylinder power on that side..
~Remember the R/H cylinder will feel like it isn't doing much [even on the duplex carb systems] as the L/H fires first with enough power to pretty well push the crankshaft past the R/H cylinder firing so the R/H will be past firing before it must work.. [under a work load both cylinders should pull pretty even].. Try shorting one spark plug at a time & see if the remaining cylinder will maintain a certain engine RPM, then short the other side & see if the RPM drop is about the same [do that at both idle & full throttle]..
~Other than that, try swapping as many parts between sides until something makes a difference..
[email protected]
Chris Armes
03-24-2004 17:44:40
Hey guys I didn't mean to stir anything up, I just wanted help on a problem 60. Manifold surfaces are in great shape and sealing well, I've already done the unlit propane torch test. Tested with two known good carbs, same thing. I'm pretty sure I don't have a valve hanging up as I have done a compression and leak down test, all good. Maybe Clooney can shed some light on my dark situation :-)
Thanks again in advance (I think).
G-MAN
03-24-2004 13:37:23
In addition to what buickanddeere said, I would take a look at the valve lash and make sure it's correct with the engine HOT. If the rockershaft and/or rocker arm bushings are worn, they can be a bear to set accurately. Perhaps you have a valve hanging open a little bit bleeding your compression off. My two cents.
buickanddeere
03-24-2004 11:44:10
The cam could well be done but before tearing in that far have a look at the manifold(s). Leaks between the head/manifold, carb manifold and cracks anywhere in the manifold are all too commom. Dirt in a carb circuit is commom and tough to remove. Sometimes those steel balls have to come out. Make certain ever passage is rodded out. A couple are almost invisible unless you know they are there. Throttle blade and throttle shaft bushing have cannot be worn or out of place. Autolite 3078 is a non resistor version of the 388. Can't hurt to try them. Autolites with an odd number in the 2nd last digit are all non-resisitor.
Say What
03-24-2004 15:13:37
 Re: Re: 1953 John Deere 60 Possible cam problem? in reply to buickanddeere , 03-24-2004 11:44:10
Hey buick I don't know where you got your plug information from but it is screwed up. The 3078 is a 7/8 plug the 388 is 18mm plug. I just called my plug supplier they said the 388 isnt a resistor plug like you said. All the old engine places sell the 388 for old engines no way would they sell resistor plugs for that old iron.
Earl S.
03-24-2004 18:57:08
 Re: Re: Re: 1953 John Deere 60 Possible cam proble in reply to Say What, 03-24-2004 15:13:37
I just looked in my Autolite plug book and they don't make a 3078. (7/8-18 std plug is 3076.) (7/8-18 hot plug is 3077). (18mm plug 3116 is the nonresistor.) (386&388 are both resistor.) 18mm heat range chart the 386 is cold, 3116 a little hotter, 388 top of the chart "hot" I hope this helps. Earl
buickanddeere
03-24-2004 16:49:51
I should have posted from home instead of trusting my memory while at work. Pretty certain the 3078 is just a hotter 3076 however. The Autolite info I have here lists the non resistor #3076 for the various A,B,G,H,D,GP,L,50/520/530,60/620/630,70/720/730 as a 7/8-18 thread. For the resistor version it's listed as just 18mm for the 386/388. The 420/430/440 take the 14mm non resistor #216 or premium MP4316. Cranking engines use a #295 non resistor.
Say What
03-24-2004 17:09:05
 Re: Re: Re: Re: 1953 John Deere 60 Possible cam pr in reply to buickanddeere, 03-24-2004 16:49:51
You better throw that autolite info in the trash. Dont sound like you done much work on those tractors either. Don't know how you figuer one of them 7/8 in. 3076 or 3078 plugs will fit in those 50/520/530,60/620/630,70/720/730 18mm holes but you going to need a great big hammer to do it. Them 386 and 388 plugs arent resistor plugs neither. You guys read to much junk put out by people that don't know no more than you do.
Earl S.
03-24-2004 20:38:44
 Re: Re: Re: Re: Re: 1953 John Deere 60 Possible ca in reply to Say What, 03-24-2004 17:09:05
I think you had better learn to read. I didn't say 7/8 18 would fit,that series of tractors. I was just correcting the fact they don't make 3078 Autolite plug. Do you have a book and know how to read a heat range chart.It says right in the book on page 278 386&388 are standard resistor and 3116 is Power tip Non- resistor.As far as my ability you don't know me from smoke. Post some black and white out of a Autolite plug book. Thank You and have a good evening.
buickanddeere...says who
03-25-2004 11:42:51
 Re: Re: Re: Re: Re: Re: 1953 John Deere 60 Possibl in reply to Earl S., 03-24-2004 20:38:44
>Link
>Link
There�s my proof, where is yours?
Say What
03-25-2004 15:07:02
 Re: Re: Re: Re: Re: Re: Re: 1953 John Deere 60 Pos in reply to buickanddeere...says who , 03-25-2004 11:42:51
buick I don't have to prove nothing to you but just to show you how wrong you are I don't suppose you have any parts books for those styled tractors you can pick any xcept the old D. You go find me one plug in any of those parts books that arnt 18mm. I know you won't be able to handle those no 6 or no 8 comm plugs so stay with the AC plugs like ac 88L or ac C86. You can read cant you.
buickanddeere
03-25-2004 16:53:02
 Re: Re: Re: Re: Re: Re: Re: Re: 1953 John Deere 60 in reply to Say What, 03-25-2004 15:07:02
You are going to have to explain yourself better and exactly what you are trying to prove. Even after proof right from the Autolite site you can't admit you are wrong. At least I can admit transposing a number. And run your spelling through a spell checker while on a rant please. We all also noticed that you are a coward and won't post your name, preferring to take cheap shots from the shadows. The Dubuque's such as the 40/420/430/440 use a 14mm, what's your point? AC #45L or Champ H10 by the way. Already found something other than 18mm long before you asked. Can you read? Some old D's used a 1/2" pipe thread instead of a metric thread. From serial number 30401 (1923) to 109943(end of 1930 production). That's a Champion #25,Autolite #3095 or a MotoCraft #F11. Deere part #508R. The AC C87 crosses to a Champ D21 and the AC C88L crosses to a Champion D23. The C86 is likely one step cooler, couldn't find it on short notice or perhaps it never existed? We won't get into those Champion duds with the U prefix as they tried to use a dual gap system to keep operating when fouled. Good idea, just didn't work. The old Champ #6 Com crosses to an Autolite B7 or an AC 84. The #8 Com crosses to an Autolite B9 or Autolite 86 Please clearly explain the intent your question about manuals, the D and pipe thread. Diversion away from your error? Myself or someone on the board maybe able to help you. We were concerned about a 60 and tossing some ideas out for consideration. A none resistor secondary system can sometimes assist the old "weak" point ignition systems.
