1940 JD A Flywheel
JR in TX
03-24-2004 08:30:03
I have a 40 A which had been converted to electric start. I am going back to hand start. I have a hand start flywheel that I removed from an early 40s A. There is one extra deep keyway cut in the flywheel which engaged a setscrew on the OD of the crankshaft spline. This setscrew also exists on my 40 A. Will this insure that I install the new flywheel in the proper position on the crankshaft? Are these setscrews always in the same position on all crankshafts?
The reason for the question is that I have been instructed to mark the flywheel/crankshaft relationship for reassembly. But, it looks to me as if the setscrew and keyway will only allow the flywheel to be installed in one postion.
Thanks, James
Clooney
03-24-2004 13:23:53
 Re: 1940 JD A Flywheel in reply to JR in TX, 03-24-2004 08:30:03
JR, as far as I know the set screw is in the same place between tractors but I haven't actually clocked them out to verify that answer..
~To install that flywheel [& be sure it's on correctly],, just rotate the crankshaft until the L/H piston is at the very top of it's stroke [use a stiff wire in the spark plug hole] , then install the flywheel with it's slot horizontal [parallel with the ground] & the L/H impulse writing to the rear.. If the set screw lines up with the deep flywheel spline [good],, if the set screw doesn't line up just use a screw driver & remove it, then install the flywheel without it..
~OR, turn the original flywheel so the L/H impulse mark lines up with the case mark [at 3 o'clock directly behind the flywheel & at the same height as the center of the flywheel] at that time the slot in the flywheel should be running directly fore & aft,, then mark the exact top of the crankshaft on it's end [in case you accidentally move the crankshaft],, then just slide the old flywheel off & slide the new one on the same way the old came off using the flywheel slot as a visual guide..
[email protected]
JR
03-24-2004 14:10:05
 Re: Re: 1940 JD A Flywheel in reply to Clooney , 03-24-2004 13:23:53
Thanks Clooney, I was hoping you would confirm this. Everything seems to line up just like you describe. Like I said, I just started questioning the position because I have had several people say "make sure you mark the flywheel and shaft". Looks to me like JD took care of the alignment with the setscrew and deep spline! Thanks again, James
