4020 pump question.
Jack
03-24-2004 05:20:52
Will a 4020 pump fit a 4010 motor without any modifacations.I have search all the archivers,and can't find a concrete answer. Is it going to have turned down so I won't give it too much fuel.I think it will but, really wanted a answer.Don't want to screw up.But don't have the $5-600.00 to get my old one fixed.If this is a dumb question ....I will not ask again..... ..... ..... ..... .Thank You
DON
03-25-2004 13:38:38
 Re: 4020 pump question. in reply to Jack, 03-24-2004 05:20:52
SET THE 4020 PUMP TO 8* IF THE PUMP WAS MODIFIED WITH SPEED ADVANCE THE FLYWHEEL SHOULD BE MARKED ,AND DONT WORRY ABT THE FUEL SETTING. MOST PUMPS ARE TURNED UP ANYHOW. MIGHT SMOKE ON A HARD PULL OR ACCELERATING, BUT THE 4010'S WERE SMOKERS .
Jack
03-25-2004 16:20:33
 Re: Re: 4020 pump question. in reply to DON, 03-25-2004 13:38:38
I sure want to thank you guys for the help...Till you are better paid...God bless
jdemaris
03-24-2004 07:14:33
I can't see why you can't swap as long as they are both Roosamaster DB pumps. Some 4020s have CB pumps which as quite different. Two big differences though between the 4010 and 4020 pumps are fuel delivery and timing advance. I don't have all the specs. in front of me, but . . . you'll probably have to experiment with adjustments. I've swapped pumps between 4010s and 4020s, but it's been a long time. First of all, fuel delivery shouldn't be a big problem. We used to turn most of them up anyway. You can always turn it down with the pump on the tractor, it's no big deal, if you get too much black smoke or the engine runs too hot. More of an issue is the fuel timing advance. 4010 is supposed to have pump installed with initial timing set at 14 degrees before top dead center, whereas the 4020 gets installed at top dead center. As I recall, that's because the 4020 pump is set with more automatic fuel advance, which is adjustable with a trimmer screw while on the tractor. If installing the 4020 pump, I'd try setting the initial timing at top dead center first, and see how the tractor runs.
