430 clutch problems?
Scott in SC
03-24-2004 03:57:10
I drove a JD 430 yesterday that I'm thinking of buying. When you let out on the clutch, no matter how slowly, it suddenly catches and will nearly throw you off the back.What could be the problem here? Thanks in advance, Scott.
Dan
03-24-2004 07:14:54
 Re: 430 clutch problems? in reply to Scott in SC, 03-24-2004 03:57:10
I have a 430 U and have changed clutches on it a couple times. It was worn out not grabbing like you indicate. Not hard to split and with mine when I have my concrete weight on the back it almost balances the rear part. How is the clutch adjustment? do you have any free travel on the pedal? Sometimes when a tractor sits for a long time the clutch will get grabby, know my G does. The 430 is a nice little tractor and mine has been relatively maintanance free inspite of being somewhat abused by the former owner.
Steve
03-24-2004 05:54:05
third party image
Could also be oil on the disc. May sound strange but this will cause a disc to grab sometimes. Another thing it could be is a ceramic disc. They are noted for being more aggressive. If you need replacement parts keep us in mind. And be sure to visit our website. See link below
Henry J
03-24-2004 05:07:29
Scott
I would think things are a real mess in there. Maybe the lining has partially came loose causing the disk to bite into the pressure plate or flywheel. You didn't say whether it was a single or two stage clutch (live or not pto). The two stage may really up the anti if both clutches are bad.
The good news is that used parts are readily available and you don't need a pile of special tools to plit the tractor.
One thing to keep in mind is that the usual comment it that "it ain't much of a job to put in a new clutch." The deal in my mind is that if all the broken stuff is so easy and cheap to fix then why do the tractors go up for sale needing repairs. Technically, I would think that that bummed out clutch should be worth about a 1200 discount.
good luck
