JD #3 Power Block????
JDVan
03-23-2004 19:17:58
In one of my weaker moments, on my recent trip, I picked up a 6" #3 Power
Block (for late JD A's or early 60's, including aluminum Pistons and rods.
I know less than I should know about Power Blocks. I don't totally yet know
the real condition of this block, the sleeves or the pistons as the pistons
are stuck in the cylinders. I am gambling I can do something with this thing
and still come out ok. It may be a foolish experiment but we only live once.
I asked several people at the GOG about this before I bought it and learned
a little about Power Blocks. I'm looking for anyone on the list who has any
experience messing with these things who might educate me a bit more. I have
learned that new sleeves are not available and if new ones are needed they
have to be custom made and are very expensive. I also was told that I might
be able to bore the current sleeves by 1/8", if necessary, and then use G
Pistons which are 6 1/8". But G pistons don't have the tapered top outside
edge that a Power Block Piston has. At least not the G pistons I have seen
so far.
Anyone out there willing to educate this, maybe foolish, gambler on Power
Blocks? BTW, the block itself looks real good. Wish I could say the same
about the sleeves! :-)
This could be a fun kind of experience or maybe a really expensive lesson!
:-) I think I purchased this at a low enough cost so I can afford to do some
fixing. But I sure don't know what is necessary yet.
I'm lost in the wilderness of Power Blocks!
Eric Horne
03-24-2004 10:06:22
 Re: JD #3 Power Block???? in reply to JDVan, 03-23-2004 19:17:58
Another good source for power block info would be to search this board for the names Dave Wickman or wtw (same guy). He has put a lot of power block info on this board.
Ken C.
03-23-2004 19:37:01
I'm no expert, but have had a little dealing with some. It can be bored out .045, .090, or .125. Don't clean it in one of those vats at a machine shop because it could ruin the o rings. It will have to be bored by someone who has a big enough bore machine because it has to be bored from the bottom up, and that puts the bore bar at the top of the cylinders when it's more likely to start chattering and cut ridges in the cylinders. The top of the cylinders are smaller to be able to use stock head gasket. You can get pistons from Hinrichs Supply, i can get the number if you need it. It will make quiet a bit more power with the power block. Hope this helps, Ken.
JDVan
03-23-2004 19:49:32
 Re: Re: JD #3 Power Block???? in reply to Ken C. , 03-23-2004 19:37:01
Thanks, that is really helpful. I would appreciate knowing how to contact Hinrichs Supply. I'm probably going to have to bore these sleeves and then will need new pistons.
Just to show my ignorance about Power Blocks I thought the ridge at the top was there to increase compression. But now I understand why it needs to be there to use standard gaskets. Thanks.
Ken C.
03-23-2004 20:00:52
 Re: Re: Re: JD #3 Power Block???? in reply to JDVan, 03-23-2004 19:49:32
It's Hinrichs Repair,815-499-6580 or 815-778-1900. He can fix you up. Also when you put the block on you will have to put pistons in block first and then slide up and bolt on rods to crank because of the small top still being 5.5 inch and pistons are 6 inch standard. If you don't get Green Magazine you may want to, it has a lot of good info and business ads in it. Ken
JDVan
03-23-2004 20:13:01
 Re: Re: Re: Re: JD #3 Power Block???? in reply to Ken C., 03-23-2004 20:00:52
Thanks Ken. I do get Green Magazine but in the past I haven't been paying much attention to this kind of stuff. Didn't have a reason to. But when I found this Power Block for sale, at a reasonable price, I just couldn't pass it up. Now I'm trying to catch up. Thanks for all the info.
Mike
03-24-2004 18:42:11
 Re: Re: Re: Re: Re: JD #3 Power Block???? in reply to JDVan, 03-23-2004 20:13:01
Powerblocks are nice, but they do tend to leak water internally into the oil, most have problems, I hope you do not, I had two , one leaked and one didnt, yes, pricey to fix, last time I checked was with Dengler out in Ohio and sleeves were like 170.00 each or somthing like that and pistons were worse, he has the tools to get the sleeves out and put new ones in, but you might be ok, and I would not have it baked out at a shop, but good old fashioned cleaning with hot water at home, if those o rings get messed up, that is more trouble, I got my leaky one slowed up with K-W block sealer but it still does leak some, just run water for a while so if it does leak, it wont ruin your rings and engine bearings, and check the oil before starting it each time, just loosen the drain plug and let any water seep out until its done, you can try alot of sealers for the price of a repair of that block.
Mitch
03-25-2004 17:17:53
 Re: Re: Re: Re: Re: Re: JD #3 Power Block???? in reply to Mike, 03-24-2004 18:42:11
Thank's to everyone for the info, I have a 47 A with a power block. Can anyone tell me how mutch power these add?
