60 battery box-what a mess.
R-man
03-23-2004 18:28:31
The battery box on my 60 is a rusted mess. Went to take it off but I'm not sure how. Found a couple of rusted stumps in the recess on each side that might have been bolts or nuts at one time but there is no way a socket will ever do anything. Do I go after it with a torch or is there a better way?
Soldier Tom
03-24-2004 06:39:33
 Re: 60 battery box-what a mess. in reply to R-man, 03-23-2004 18:28:31
On the 720, we had to impact wrench off the two good bolts, no problem. One other we were able to grind down to the good part of the bolt and get a smaller impact socket on it, no problem. The last one, (Since we have no welder) was ground around so that we could slip the seat off around it, planning to put the stud wrench on it and muscle it off. Stud wrench didn't grap enough, so we ended up taking off the powertrol top plate. Checked it out good while we had it opened up, wrenched out the stud and then torqued the plate back on. Be sure to run a thread cutter through the holes to get out all the crud before you put the bolts back in. We used hardware store bought bolts of the correct size and hardness to replace the seat. Lots of cussing, but not too physical a job.
~Walk in peace~
rkjd
03-23-2004 18:42:48
r-man, that is what i just had to do on a 630. just cut them off clean get the box out of the way then weld nuts on the bolts and they usaully turn out pretty easily. rkjd
