Grease Zerk on Clutch Collar
es
03-23-2004 17:11:54
third party image
I have the pulley off on my 70 diesel to work on the clutch an I noticed a grease zerk on the clutch collar. Am I supposed to grease this or is this supposed to be there at all?
Thanks
Clooney
03-23-2004 17:20:55
 Re: Grease Zerk on Clutch Collar in reply to es, 03-23-2004 17:11:54
ES, you have the later 720 operating sleeve on that tractor.. To grease that fitting, first snap the operating sleeve towards the pulley, then pump in high temp grease until grease appear at the toggle ends.. Deere called for a special high temp clutch lube but I have always just a used a good quality high molly content chassis grease without any problems.. You only have to grease that fitting when you pull the pulley off for bearing repacking or other work..
[email protected]
