3pt on flat back B. Clooney or anyone know.
Chris
03-23-2004 16:05:13
Anyone ever built a 3pt for a flat back. Ive got a 3pt for an H farmall im wondering if i can adapt. or would be better to start from scratch. fabrication is no problem just wondering if anyone had any pictures. thanks
John T (Update)
03-23-2004 17:54:30
 Re: 3pt on flat back B. Clooney or anyone know. in reply to Chris, 03-23-2004 16:05:13
OOps sorry Chris, I just now read your other post below and see you are indeed looking for one of those live pumps to power your 3 point. If you get it, all you need is a reservoir to feed that pump and a valve to operate your up n down cylinder and youre off to the races.
Best Wishes
John T
John T
03-23-2004 17:49:38
Chris, What model B you have??? Styled or Unstyled??? If it has no power lift, are you gonna use a 3 pt like some of the Framalls with a cylinder to raise the arms?? And if so, are you gonna use one of those live hydraulic governor mounted pumps which fits between the governor and mag/distributor?????
Sorry so many questions versus the answer you're lookin for, but Im not computign yet as to what and how you plan to proceed. I also love to home build and rig up thigns like youre talking about so am interested in how youre gonna configure it.
Let us know, Good Luck n God Bless
John T
Clooney
03-23-2004 16:34:42
Chris, I saw one last year.. It sure looked like it was patterned after a Farmall type but used a single cylinder on one side that powered a top cross shaft with lift arms on both sides.. It doesn't sound too hard to build but will probably take a fair amount of mock-up to get the function correct..
[email protected]
