40T Carb
JB
03-23-2004 14:50:04
My 40T cranks easily, idles fair, but if you advance the throttle fast, it will spit & sputter until it catches up, then runs pretty good. I put a new load needle in as it did not have one when I got the tractor, but would crank and run well. Has new Brillman wires, new plugs, spark will jump a 1/4" gap. Load needle does not seem to affect it much. Idle needle not at all. Any advice would be appreciated.Thanks.
Wayne in Tn.
03-23-2004 15:59:42
 Re: 40T Carb in reply to JB, 03-23-2004 14:50:04
JB, on those Dubuques, opening up the load needle usually stops the problem. Your carb. possibly needs a kit and cleaning. Also may be sucking air at the throttle shaft seals.
