H hydraulic lift
J.P.
03-23-2004 09:49:59
Can anyone tell me the maximum rated lift capacity for the hydraulic system on a Model H?
jeremy
03-23-2004 21:30:59
 Re: H hydraulic lift in reply to J.P., 03-23-2004 09:49:59
if you know the cylinder bore size i can figure out the lifting capacity for you jeremy
dan_41jdh
03-23-2004 20:28:30
J.P., the H hydraulic pump had a "rated" pressure of 555 psi, with a maximum relief pressure of 675-720 psi. Sorry, I can't tell you the flow rate or what the 555 psi pressure translated into force (when using the standard "H" cylinder) is supposed to be.
J.P.
03-24-2004 08:03:18
 Re: Re: H hydraulic lift in reply to dan_41jdh, 03-23-2004 20:28:30
Thanks, I can calculate the lift with these figures.
