3020 missing
Robert
03-23-2004 06:59:12
My 1965 gas 3020 has been missing lately. I had the carb rebuilt last fall,seemed fine been using it about once every other week all winter. I put new plugs, wires, points, dist. cap all either this winter or recently. Nothing seems to help. It has a Zenith carb. on it. It seems to me that the carb settings are off, but tried playing with them and it does not seem to help.
thanks
In advance.
Joe P.
03-24-2004 04:41:54
 Re: 3020 missing in reply to Robert, 03-23-2004 06:59:12
Have you checked for plug fouling or wet plugs? In other words, do you know it is a random miss and not just one specific cylinder? And does it miss all the time or just when cold? or under power?
Robert
03-24-2004 05:31:16
 Re: Re: 3020 missing in reply to Joe P., 03-24-2004 04:41:54
It started when cold and now seems to do it constantly. I had changed plugs last fall, but I guess it would not hurt to check again.
thanks
S. Conner
03-23-2004 10:57:15
You might want to open the drain valve on the bottom of the fuel tank to let any accumulated water and dirt out of the tank. Water is heavier than fuel so if there is any in there it will drain out first. Also if you have a fuel filter, check and/or replace it. I've got a 4010 gas and these are a couple things I've had to do. You may also want to check the ignition timing. I put electronic ignition on this tractor and that is one of the best things you can add to an old gas engine tractor. No more headaches of changing points and re-setting the timing.
Robert Barcus
06-16-2004 18:18:55
 Re: Re: 3020 missing in reply to S. Conner, 03-23-2004 10:57:15
S Conner, where did you get your electronic ignition kit? From JD? I know they have one.
Robert
Larry
03-25-2004 09:30:43
Once you get the water out of the fuel, adjust the float to allow more fuel in the carb. I made mine a little higher than specified. My 3020 would skip under load and it was just a lack of fuel problem. If it runs good rich (black exhaust) then adjust the carb. per the operators manual. If you do heavy work with it, the load screw will need minor adjustments to run good.
DON
03-23-2004 07:58:59
DO YOU HEAR ANY EXVALVES WISPERING TO YOU WHEN YOU SHUT THE ENGINE OFF.LISTEN CLOSELY AT THE MUFFLER. DON
Robeart
03-23-2004 08:15:58
 Re: Re: 3020 missing in reply to DON, 03-23-2004 07:58:59
I am not sure what you mean or are getting at?
