2520 3-pt lift height
Festus
03-23-2004 05:16:10
I recently bought a 2520 and have noticed that the 3-point doesn't lift very high. Just barely high enough to get a plow out of the ground. With the implement off & the lever in the fully raised condition, I can manually pick up on the lift arms and raise them about a foot or so beyond what the tractor will lift. Is there an adjustment to get the lift arms to raise to the maximum height? Thanks!
John 51
03-23-2004 09:36:04
 Re: 2520 3-pt lift height in reply to Festus, 03-23-2004 05:16:10
Yes, I adjusted mine last summer. It's an easy process. Remove the sheet metal under the right side of the seat to expose the linkage that controls the lift. There is an adjusting clevis on the linkage. Just shorten or lengthen it as needed. I did it one turn at a time, trial and error, to get it right. The hardest part of the process was removing the cover to get to it.
