1964 4020 LP Powershift problems
J Imhof
01-23-2004 20:26:08
When shifting from 6th to 7th the tractor acts like its under extreme load and will die very fast unless you press and release clutch or either brake. Once cluth or brake is pressed and immediately released tractor runs in 7th fine and then shifts to 8th fine and downshifs through all gears fine. Also the PTO does not fully disengage. It can be stopped with moderate resistance on the PTO output shaft but when released takes off again. Can these problems be adjusted or do I have more problems than I want to imagine?
Justin
01-25-2004 19:08:30
 Re: 1964 4020 LP Powershift problems in reply to J Imhof, 01-23-2004 20:26:08
Any idea on cost of repairing this pto problem? If to high I will have to sell it. Also if unable to solve 7th gear hard shifting can it be operated as is without harm by shifting into 7th using the inching pedal? Any insight would be greatly appreciated.
Russ
01-24-2004 17:17:26
1964 4020 Tranny fix; Sounds like Don's string has laid out the repair scenario. Would you go the fix or send the rig into the market? Imagine the repair bill will be a bit JD pricy.
DON
01-24-2004 13:50:49
3-5-7 TH GEARS ARE OVERDRIVE IN THAT TRANSMISSION. USE MORE THROTTLE OR THE INCHING PEDAL. THERES A PLANETARY PACK THATS HEAVY IN THERE THAT SUDDENLY HAS TO SPIN ENGINE SPEED, THATS WHY IT PULLS DOWN. CUSTOMERS THOUGHT THE POWER SHIFT PULLED HARDER BUT THE POWER LOSS WAS ONLY ABT. 3 HP EXCEPT WHEN SHIFTING VERSUS 5 HP IN THE SYNCRO. ANOTHER REASON WAS THEY WERE GEARED A LITTLE FASTER. THE PTO BRAKE FACEING HAS COME OFF OR WORN OUT, OR THE C-2 PACK AND PTO PACK ARE DRAGING. THE TRACTOR WILL HAVE TO BE SPLIT BOTH AT THE CLUTCH HOUSEING AND THE TRANSMISSION TO FIX THE BRAKE FACEING. DON
DON
01-24-2004 13:45:46
Roger
01-24-2004 10:01:37
I have an'82 4440 ps. All of the pwr shifts pull down some going to 7th, & 3rd will jerk the h^$% out of you it's a trait of the 8 speeds,my '69 4020 was the same way, a 15 speed isn't like that, nice & smooth. Like G man said you may have something sticking or not working right that will just make it shift that much worse. On pg 50 of the 4020 tech manual it mentions the use of 2 clutch packs at the same time (4th to 5th & 6th to 7th) I dont remember 4 to 5 doing it, I always thought it was going to 3rd like the 4440, but it's been 14 years since I traded the 4020.
G-MAN
01-24-2004 11:23:23
 Re: Re: 1964 4020 LP Powershift problems in reply to Roger, 01-24-2004 10:01:37
Yes, there are gears that use C1 and C3, or C2 and C3, but 7th is the only one that uses all three clutch packs. C1 and C2 are located together in the clutch pack itself, along with the PTO clutch, and C3 is located in the planetary brake pack. The 12-13 and 13-12 shifts are generally rough in the 15-speed powershifts for the same reason - you're picking up that third clutch pack.
G-MAN
01-24-2004 09:21:26
7th gear is kind of odd in the 8-speeds, as it's the only gear where all the elements that are applied function in direct-drive mode. In 7th and 8th, both C1 and C2 clutches are applied, whereas in other gears, only one or the other are. C3 is also applied, and this can lead to heavy loading of the engine, but it shouldn't completely kill it. I'd check the system pressure and do clutch-drag tests. The manual says that engine-overloading in 7th can be due to a stuck shift or dump valve, so I'd recommend getting a service manual and following the diagnosis in there. Powershifts get involved pretty quickly, and it's easier to follow it in a book than on a computer screen.
