HELP SAVE A GATOR; do your part...
Robert
03-23-2004 03:36:04
I have a 6x4 Gator with a 20 h.p. Kawasaki. The spark plug that is to the rear of the vehicle keeps fuel fouling the front is like new. Compression is 150 per side , swapped ignition coils, tried different brand plugs,
Thanks for the help
tom
03-24-2004 08:30:31
 Re: HELP SAVE A GATOR; do your part... in reply to Robert, 03-23-2004 03:36:04
I too have 6 X 4 gator, about a 96-97 model...not too many hours...weekend usage at best.
I have found that these machines need to be run hard to maintain a smooth running status...meaning, if you put around in them too long, the plugs foul and the engine runs sluggish.
a tip is when you first start her up, idle high to warm up, then take her for about a 2-3 minute spin at WOT...then, do not let her idle too much between tasks, just turn off and restart when needed...
tom
Daryl
03-23-2004 19:00:52
I had one of the first gas gators built. I had it completely melt the elctrode on the plug on the rear of the engine. Tried different heat range plugs and got some satisfaction, but not enough. Bought a diesel model and that solved the problem. That Yanmar diesel is definately worth a grand more!
robert
03-23-2004 07:27:52
is it liquid cooled ? chance head gasket (coolant foul)?carb float sticky,and fuel gravitys to that cyl? spark wire or boot intermitant circuit? ign.box or whats ahead of that coil going bad??
buickanddeere
03-23-2004 07:15:27
Check the valve lash. Is the cooling system working, no kinked lines, running too cold etc? May have to tear it apart to check valve seals etc. Is the fouling fuel or oil? What type of work does this gator do?
Robert
03-24-2004 03:31:03
 Re: Re: HELP SAVE A GATOR; do your part... in reply to buickanddeere , 03-23-2004 07:15:27
This Gator is used at our local jail. We have a fairly big wwork farm on the compound with alot of equipment(bales,rowers,discs ect) The Gator is used to run errands (no hauling) and to run inmates to and from the jail. It has 670 hours, It does not appear to have a cooling problem I did put a temp probe at the heads though I don't remember the exact temp. it was normal. I considered valve lash but the compression was good however I will check that since it is fairly easy. It is gas foul only at the rear plug and the manifold looks to be uniform to the front and rear cyl's Thanks again for any help
