Distributor advancing on 51 JD A
OL Gray A
03-22-2004 17:32:38
Should the rotor move when turned by hand? I don't think the dist. is advancing. The tractor has a rough idle unless I adjust the timingand then it is rough at full throtle. Can Anyone tell me anything?
Haywood
John T
03-22-2004 19:48:24
 Re: Distributor advancing on 51 JD A in reply to OL Gray A, 03-22-2004 17:32:38
Good evening OL, yes, the rotor (assume youre talkign about a Delco Distributor???) is free to move somewhat, cuz rememebr its supposed to advance as centrifugal force moves those weights out against the spring hold back tension. If you put a timing light on the left plug and watch the flywheel, as RPM increases so should spark advance. At idle she shouldnt be much advanced and very little when cranking, so if the advance as observed by a timing light is okay, you may wanna take a look at the carb and other things.
Best wishes n good luck with her n God Bless ya
John T
Clooney
03-22-2004 18:24:54
OL Gray A, yes it should move in the advance direction..
~To check your dist advance just put a timing light on the L/H spark plug wire & point it at the flywheel after you pry the little cover out of the center of the big flywheel cover.. If your timing is advancing you should see the dot on the flywheel hub move SMOOTHLY in the advanced direction as the engine RPM is slowly increased from idle through wide open..
~If you have problems, or the timing isn't advancing smoothly, or you aren't getting an advance at all just post back or E-Mail & tell us if you have a Delco [round body] or Wico [squarish body] distributor..
[email protected]
