Robert: Yup, you'd be able to buy a lot of those switches for the cost of a coil.... Anyway.... Yes, the basic tenet of the switch operation is to close and provide power to the coils only when the pony is making sufficient oil pressure to close it. Also, we maintained the by-pass wire from the starter motor switch to power the distributor with straight 6 volts power during cranking when the voltage is drawn lower by the starter motor load (this is original per JD). Additionally, the other switch lead powers the dash red ign lamp which will glow when the oil pressure switch is powered, but not closed, SO, when you turn the ign switch on, the lamp glows, you start the engine, it goes out, and when you shut down the pony (and by now the big diesel is running and making lots of noise), the red lamp glows again telling you to return the ign switch to off or lights. It also shows you the system is working. You don't have to wire it that way, but often times it reminds me to move the switch to "OFF". BTW, Taylor's in Michigan is a good source for coils, as well as Magneeders. Also, I have found that the aftermarket coils these days seem to like the voltage held a bit higher than the original 4.7 volts, so you might have to monkey with the resistor a bit to trim it out to a good voltage. Working from the low end up until it doesn't want to miss under load. Frank-in-Tallahassee �56 70D // �90 855 // �50 VAC // �48 Cub [email protected]
