 Rick: I think I can help. I also have a 45W loader, and a 70 Diesel. The cylinders are the same 45 or 45W. On the rod end of that cylinder is a vent that was used if the loader was operate by a -20 series or newer series tractor. Your oil leak is coming from the by-passing of oil past the leather cup or o-rings (depending on the exact vintage of your cylinders) and then out the vent. I would think that you have gravity down rather that pressure down right now. The easiest/best fix would be to equip your loader cylinders with an additional front hose. This will allow the oil to blow past, but stay in the sytem. It will also kep you from ever running out out oil reservoir capacity from the Powr-Trol, because the cylinder will hold oil on both sides of the cyclinder piston. I run my hoses from each cylinder to the rear, then connect them together, then up to the Powr-Trol. I have a hydraulic bucket, so it all joins at a mast mounted valve as well. Sorry for the large pix....the loader has since been painted. I have lye gravy smeared all over it prepping it. You'll be much happier after you install hoses on the fronts. Frank-in-Tallahassee �56 70D // �90 855 // �50 VAC // �48 Cub [email protected]
