Help! How do I reassemble 420 clutch parts?
Steve in TN
03-22-2004 08:35:48
I'm working on a complete 420w restoration. All parts cleaned and repaired. Now the assembly! Trans and final drives complete and together. Now the center housing. When I tore it apart, most of the clutch parts were wallowed out or shot. So two questions: Is the clutch control rod supposed to be straight? Mine has a few bends in it. Should I straighten them? Secondly, how do you install the adaptor (MT 4219 T) and the sleeve (M 4215 T)? Do you glue them into place? What holds them in the casting so they don't ride out? Which way does the adaptor fit into the casting? Mine seems to fit well with the ridge toward the front, but the parts manual showes it toward the rear. Anyone know?
Henry J
03-22-2004 16:56:40
 Re: Help! How do I reassemble 420 clutch parts? in reply to Steve in TN, 03-22-2004 08:35:48
Steve
I will give you and Wayne something to scratch your head about.
You did not say what kind of clutch you had - single or two stage. I will bet you and Wayne a big mack that the rod for the tow stage clutch has a jink/bend in it down close to the pedal end. I don't know anything about the single stage. I think the jink is for clearance to get the rod by the large tube that is the drive shaft for the pto on the two stage clutch.
The one I threw in the trash and the used one I installed had the same off set in it.
Have fun in there and if you do have a two stage clutch, I have had the pleasure of having to make a tool to set the clutch up - school of hard knocks lol.
Wayne in Tn.
03-22-2004 10:47:17
Steve, that clutch rod should be straight. That is a problem I have run into, that rod will bend or flex, causing improper operation of the clutch. I have had to lay another steel rod alongside it and weld them together to reinforce it and stop the flexing. If you will look close, you may can see where the rod has been scrubbing the inside of the housing...its not supposed to do this.
As to that adapter, I have never been into one that has it. The ones I have seen only have the 4215 sleeve. On those... the sleeve is just sort of pressed into the housing to keep it in place.
This is another area I have had problems with, the sleeve will come loose and come in contact with the pressure plate and will destroy the fingers on it. To stop this problem, I usually tack weld the sleeve to the housing, to avoid any future problems.
Steve in Tn
03-24-2004 20:59:36
 Re: Re: Help! How do I reassemble 420 clutch parts in reply to Wayne in Tn., 03-22-2004 10:47:17
Thanks Wayne for the advise. Thanks too to Henry J. BTW, it is not a two stage clutch. One more question on the tube. Should it be slipped all the way into the adaptor/ casting? Or put another way, how far should it stick out? Is there a measurement? thanks again!
