Torque Specs For Manifold??
52BMAN
03-22-2004 06:30:09
Does anyone know the torque spec for the nuts that hold the manifold on, for a late styled B? Thanks for your help.
Earl S.
03-22-2004 20:50:48
 Re: Torque Specs For Manifold?? in reply to 52BMAN, 03-22-2004 06:30:09
7/16 grade 5 dry 52ft. lb. 7/16 lubed 41ft.lb.
7/16 grade 8 dry 75ft.lb. 7/16 lubed 58 ft.lb.
Duane Larson
03-22-2004 08:59:10
52BMAN,
The JD Field Service Bulletins give torque values for many bolts, but not the manifold. Neither does the I&T manual. About your only guidance at this point would be the torque value for the size bolt holding the manifold. There has been good info on this site from Clooney and others about proper torque values, whether to lubricate or not, etc.
