2 questions
Stu
03-21-2004 18:49:04
One: whats the deal with 'dent' and 'no dent' mufflers. I seen reference to both, my 70D has an oval dent at the bottom of the muffler, is that it? Does it mean anything?
Two: My 70D has manual stearing. I have the nose and tin off, and want to service the pedastal fluids. My manual calls for a hypoid lubricant?... what do you guys suggest, I dont know what that is. Also, the current oil level is above the gear and the manual says to be just up to. I see no drain, do you guys use a transfer pump to suck it out?
STU
Dan
03-22-2004 07:20:08
 Re: 2 questions in reply to Stu, 03-21-2004 18:49:04
I remember the Hyploid oil when I was younger, not sure if it is still made or what the substitute. It was in 90 wt or 140 wt oil I believe and we used it in the transmission of our g. Main characteristic I noticed was it really smelled funny. I would think 90 wt gear oil would work fine.
CLW
03-21-2004 19:55:50
Stu, the dent is for the tractors that the steering rod would rub if it were not there, such as the late styled A. The 70 would not require the dent but a lot of aftermarket mufflers have them. If you wanted the correct muffler Correct Connection has them. The dent sure won't hurt anything on any tractor that it will bolt up to. Can't help with the fluids.
CLW
