Added plug washer
Stretch
03-21-2004 18:37:24
John T had an interesting and informative article in the March issue of Green Magazine about "Reducing spark plug fouling." It was especially helpful to someone like me who is relatively "green" at this John Deere thing. In the article he states that using an added plug washer under the plug will raise its operating temperature. Why is this so? Are you out there John T? Once again, thanks to everyone for their help.
John T
03-21-2004 18:58:08
 Re: Added plug washer in reply to Stretch, 03-21-2004 18:37:24
Stretch, A spark plug dissipates its heat from the hotter inner portion of the cylinder where the hot combustion chamber and gasses are to the relatively cooler mass of the iron block. Therefore, if you introduce extra material and/or space or something that hampers heat transfer (like old farmers trick of an extra plug washer) the plug runs hotter which can help to burn off the potentially fouling deposits like unburned fuel, carbon, or oil etc. Thats why I suggest (when not using the tractors under load and at temperature) one run a hotter range of spark plug or do other things that hampers heat transfer like an extra washer or running a lean fuel mixture (so long as rich enough to produce power) or running the timing a tad retarted and keeping the ignition tuned to the max to produce all the spark energy possible. Ive not found fouling near as bad a problem on battery and coil ignitions as on the older unstyled units equipped with magneto ignitions. Its the low temp light load parade situations I was trying to address to reduce plug fouling.
Hope this explains how heat transfer is reduced and can raise the plugs operatign temperature. However, Im an electrical not mechanical or thermo engineer, but we had to grunt throught some of that stuff lol.
Good Luck n God Bless
John T
Clooney
03-21-2004 18:55:45
Stretch, that double plug gasket came from a thread I posted a few years ago on how to stop plug fouling on a Deere 40.. The basic idea is the center electrode heat has to travel farther to from the plugs center electrode to the cylinder head or engine block.. That second gasket insulates a little more of the heat transfer of the plug base to the metal it's screwed into.. That second gasket doesn't make a great difference but does help a little.. What happened was that I was using a plug gasket thermocouple under a spark plug for a plug temperature test & after a spark plug change the plug temperature went up.. I thought I had the incorrect plugs installed but it turns out that a production plug gasket was also left on the spark plug.. So with that idea in mind I tried a double plug gasket on a Dubuque engine that was fouling plugs & it seemed to help...
[email protected]
Bob
03-21-2004 18:48:42
The temperature range of spark plugs refers to it's ability to transfer heat to the block or head they are screwed into, so that for a given engine, or load, the tip of the sparkplug does not reach an incandescent temperature that will pre-ignite the fuel charge as the cylinder is coming up onto TDC. On the opposite hand, the plug needs to be hot enough so fouling deposits are burned off.
The theory is that the extra washer will retard the flow of heat from the sparkplug to the surrounding metal much as going up a heat range, or so would do.
