Mike, that nice Deere 2-cylinder clutch snap is from the toggles going over center as the operating sleeve snaps out against the pulley.. For some reason your toggles aren't snapping over center but if the clutch stays engaged they must be going over center enough to stay there.. That is why you are getting a snap on release.. ~The usual place to start is with the pivot pins but you have already resized them.. Did you just drill the centers of the worn pin holes? If so that could part of your problem.. Those pin holes usually wear in only one direction [wrong direction] & if you just drilled them out & installed larger pins they are still centered in the wrong spot.. ~The next place to look is at the anti-rotational pin & pin hole in the operating sleeve.. If that sleeve isn't maintained in the factory position the toggles will go sideways as they try to go over center so the lift will be shorter & they won't go over center correctly.. ~The next obvious place is the toggle pockets in the operating sleeve & pivots... If the bottom of those holes are worn at an angle [or deeper] that can cause a snap in problem.. ~Sometimes adjusting the clutch so it doesn't snap in so firm can make it snap in with a more pronounced snap.. ~There are a few ways to go after your problem... One is to just throw a bunch of expensive new parts at it [sometimes that will repair it, sometimes it won't].. Do to the difficulty in seeing the wear problem or measuring it you are going to have a difficult time in finding the bad parts [probably a little wear on everything]... What can work [I have done it many times] is to grind about .020" from the pulley side of the operating sleeve, that allows the operating sleeve to move outboard farther so the toggles go over center a little farther & will then snap in with a little better snap.. ~OK now that I said all the above you might start with something easy.. Deere offered a set of conical washers to help the snap in problem [part number AR 21803R].. If your clutch doesn't have those washers under the adjusting nuts start there as that might be all it takes to make your clutch feel better... [email protected]
