Hey smoker, you done did most of our standard generator versus Voltage Regulator troubleshooting, so now we gotta ask a few more questions and try a few more tests: QUESTIONS/ASSUMPTIONS 1. I assume youre still at positive ground?? Gen is well grounded to tractor and VR well grounded to Gen?? Good tight belt?? When you polarized you got a small spark??? Ammeter polarity is correct (swing to discharge if lights etc applied)?? 2. Im wondering maybe if your armature is shorted or your fields are shorted????? ????? ??? a) With the armature removed, if you place a contunuity checker on the shaft and all the commutator segments, theres NO SHORTS RIGHT????? If there are, the armature is bad shorted (may have that burned electrical smell), you cant have continuity between any segments and the iron shaft core. Is the commutator cleaned up???? b) With armature removed, there SHOULD BE continuity in BOTH fields as evidenced by a continuity test between the Gens ARM and FIELD posts BUT THERE SHOULD BE NO CONTINUITY between either post and frame ground or you have a shorted field winding. Be sure the gens internal wiring from the ARM post to the brush isnt shorted to case, the field winding(s) crossover mid tie point wiring isnt shorted to case, and again, the field windings not shorted to case. YOU SURE SHES ALL WIRED CORRECT?? Does it have a fuel gauge switch?? Bat on VR is hot at all times correct??? Arm on VR to ARM (larger of 2 posts) on Gen, FIELD on VR to Field (smaller post) post on Generator???? SUMMARY See if the ammeter is correct polarity,,,, wiring on Gen and VR (and any fuel gauge) is correct,,,,, ,If she sparks when you polarized,,,,, ,,If the armature is grounded,,,,, ,If the field windings are continuous and NOT grounded,,,,, and finally your new brush wiring is correct and not shorted to case (one brush wired to ARM post, other is the grounded brush) BE SURE THE NON GROUNDED (TO ARM POST) BRUSH is not shorted, yet the other brush is grounded. You might try the Generator motor test with the belt removed to see if it motors/turns (armature n brushes probably okay) then slows down if Field is grounded (Field probably okay) by removing the wiring then applying a hot battery wire lead to the Gens ARM post????? Lemme know, post back or e mail [email protected] any questions. Look for mis wired brushes or a short in ARM or Field windings assuming all else is okay and wired right. John T
