Gp rubber - question
leon
03-21-2004 05:03:17
My JD parts CD shows AC1070R rear wheels for 11.25X14 rubber tires and AC1062R front wheels for 6.00X16 rubber tires for standard GP's, 200111 and up, that is all standard GP's and for all GPO's.
Further, it shows AC1103R rear wheels for 9.00X36 tires and AC1088R front wheels for 5.50X16 rubber tires for GPWT's 400,000 and up, that is all GPWT's.
Were early GP's really available from the factory with pneumatic tires? If not, when did they become available? Or is the CD parts book just showing that these rubber tired wheels could go on all GP tractors, even back to the start of production? What did these four wheels look like? Flat or round spoke? Are part numbers stamped in the rims or cast into the hubs? Thanks for the info.
Duane Larson
03-21-2004 18:35:49
 Re: Gp rubber - question in reply to leon, 03-21-2004 05:03:17
Leon,
Answering your questions:
1) were GPs available from the factory on rubber - yes. I have a Firestone brochure dated 11/32 which lists the tractors for which rear tires and wheels were available, and the GP and GPWT are listed. It is assumed JD would have started selling them about that time.
2) the early parts catalogs are a good source of information on wheel development - yes, in general once a part was made available John Deere listed it for all s/n tractors on which it would fit - not just when it started. Again, the earlier parts catalogs do provide some starting s/n info which is lost in later catalogs.
3) what did they look like - the AC1070R rears are French & Hecht round spoke wheels with a casting number HC3 for the GP. They used an 8.00Tx24" rim for 11.25x24" conventional tires. F&H made similar wheels for the IHC F20 (HC26A) and the AC-WC (HC46A) - they were more plentiful and so often show up on GPs, ARs, AOs, BRs and BOs. But there are differences besides the casting numbers.
4) The AC1103R wheels on the GPWT were also F&H wheels with HC45 casting numbers (present thinking, but not perfectly clear). They used a 6.00Sx36" rim for 9.00x36" conventional tires. Again, one often finds HC26 rear wheels from the F20 on the GPWT.
5) the early front wheels were F&H but have no casting number as it appears the hub may not have been cast - but rather had a cast insert which contained the bearing races. Three styles of the AC1062 wheel were used on the GP - one with a screw-on hubcap, one with a hubcap held on with 4 screws, and the last wheel has a C167R hubcap, with a hub casting number HC234A. The AC1088R used on the GPWT was similar to the AC1062R, but only the wheel for the 4-screw hubcap was used. Again, one often finds F20 front wheels on the GPWT (F&H HC100) as they can be modified to fit. There are other front wheels for both the GP and GPWT but these are the "most common".
I gave a seminar at the GOG2004 on wheels, and this information is from the GP part. I can provide additional information and references if useful.
leon
03-27-2004 05:19:32
 Re: Re: Gp rubber - question in reply to Duane Larson, 03-21-2004 18:35:49
Hopefully you clicked the e-mail notifacation button because this thread is getting burried pretty deep. Anyway, GP and GPWT wheels for rubber tires, you mentioned that the AC1070R wheels are round spoke. What about AC1062R, AC1103R and AC1088R? Round or flat spoke? Thanks again, leon
leon
03-22-2004 04:15:28
Duane, thanks for the very complete response. Just what I was looking for. I was at Gathering of the Green too but was unable to attend your seminar. Too many good things going on at the same time. I did pick up a copy of your handout at the door, but the info I was looking for wasn't included in that abbreviated version.
ET
03-21-2004 06:21:26
I don't think factory rims were available until around 1934. The rims are round spokes made by F&H who made them for most all tractor manufacturers. The rims fit the early GP's as well as AO and AR tractors.
