60 compression. Clooney ???
Chris
01-23-2004 18:35:23
My 60 I checked Has 135psi checked on several gauges. Thats cold with 3 puffs of air each time. on both sides. Now is that enough to have to run a higher octane gas. The guy i bought it from 2yrs ago had just overhauled the engine but i did not ask what he did. So do i need a higher octane fuel i think i have a spark knock now.
Duane Larson
01-24-2004 07:14:04
 Re: 60 compression. Clooney ??? in reply to Chris, 01-23-2004 18:35:23
Chris,
According to JD Field Service Bulletin 212 (Feb 1954) the compression for a 60 gas is listed as "140 psi (estimated)", and FSB 247 (Nov 1956) gives 123 psi at cranking speed with the throttle wide open. Apparently they must have measured compression pressures to determine an actual value.
Duane Larson
01-24-2004 07:19:02
 Re: Re: 60 compression. Clooney ??? in reply to Duane Larson, 01-24-2004 07:14:04
Now I understand the double posts which sometimes show up - when I posted I got a time-out message from my ISP, so I reposted not knowing the first one apparently got through.
60 std
01-24-2004 07:13:41
Chris;
I had the same problem with my 60 standard after I overhauled it with new aluminum oversized pistons and had the head and block planed to flatten them. I could hear a good firing cackle when it was hot and pulling a load. I did a cold compression check with it showing a little over 130# during cranking. I did find that using premium gas made the noise go away when pulling a load. One day my good friend and neighbor was over and we got to talking about the compression and how it might be effecting my engine knock so he helped me do another compression check. What we found was the compression was a bit higher on a hot engine and went up to about the high 140# range. He brought his timing light over and we checked the timing and found it was already set to a little below 20*. My friend is a mechanic for the Ford dealer in town so I trust his work. He suggested that I try mixing regular and premium gas to see if that would be enough to help the cackling under load sure enough it worked. I now use regular gas for playing around with a can of premium poured in when I work it. So far that seems to be working good.
Duane Larson
01-24-2004 06:57:22
Chris,
Mike Aylward
01-24-2004 07:06:06
 Re: Re: 60 compression. Clooney ??? in reply to Duane Larson, 01-24-2004 06:57:22
Duane, I am thinking that in my old bulletins that often compression pressure was measured at rated engine speed to get the higher figures. I would imagine this was done driving the belt pulley. I am not looking at my bulletins right now but if memory serves me right (which it often doesn't..:-) this was the way it was done. Mike
Duane Larson
01-24-2004 08:59:14
 Re: Re: Re: 60 compression. Clooney ??? in reply to Mike Aylward, 01-24-2004 07:06:06
Mike,
You are right - FSB 217 states that the values given are measured at rated engine speed by belting the tractor and adjusting to proper speed. FSB236 gives compression pressures at both "rated rpm" and "motoring with electric starter or cranking engine". For the 60 the values are (rated rpm 140) and (motoring rpm 123), both of which agree with my first note.
Thanks for the clarification! These old FSBs are a gold mine of information.
Mike Aylward
01-24-2004 06:11:08
Chris, the 135 lb. reading just means you have a good healthy 60. This level of compression will take normal pump gas without problems and do it day after day. And do not set the timing back to 15 degrees because it will absolutely kill the power on the tractor. Now, if you were talking compression levels of upwards of 160 lbs. then you would likely be looking for better fuel. If the engine is cold you are probably hearing a little piston slap which is normal for a very cold engine, or it is possible your timing is way too fast. Get the tractor warm, work it a little and you will probably not hear the noise afterward. Set the timing around 20-22 degrees ahead and you should be just fine. Mike
Clooney
01-23-2004 19:23:24
Chris, at 135 psi cold that's a little on the high side but it could still be low enough for regular fuel... I guess I would make sure the ignition timing is not running any higher than 20� BTDC at fast idle,, then use the tractor under a load & listen for spark knock.. If you hear a spark knock try richening the carb's load screw a little more & see if you can get the knock to go away.. If you still hear a knock under load try backing the timing down to about 15� BTDC... If you still have a knock under load you might have to try a little higher octane fuel..
~It probably wouldn't hurt make sure you don't have too hot of a spark plug in it & make sure the distributor advance mechanism is operating smoothly...
~Without knowing exactly what was done inside the engine you are just going to have to play it by ear [pun intended]...
[email protected]
