3020 lost of power
buckman
03-21-2004 04:22:44
just had my injector pump oh'd . ran great for about 5 hr's . i was pulling my disc she was running good , then on next pass she would start to drop rpm's , clutched it rpm's would slowly increase , start pulling again and rpm's would dropoff. throttle responce is slow . what would the problem be ?
Mike w J
03-21-2004 07:46:45
 Re: 3020 lost of power in reply to buckman, 03-21-2004 04:22:44
Sounds like pluged filters or air in the filters or a restriction in the bottem of the fuel tank. Try to bleed the filters again and if it runs good for a while then acts up again start with filters then check for pinched line from the tank or a restriction in tank . it could be the fuel pump but if it works to bleed the system then thats not probable.
david val
03-21-2004 09:19:07
 Re: Re: 3020 lost of power in reply to Mike w J, 03-21-2004 07:46:45
also check free flow in return line from pump to tank
